Starting point was an 1988 E reg 316 m10 auto carb beast. One lady owner from new, covered 53'000 miles. Full history. Car was in such great original condition I could not help myself from buying it
Main highlites so far
Body work
Replacement of off side inner sil
Replacement of off side outer sil
Replacement of off side inner wheel arch
Repair to rusty lower front wind screen panel
Removal of rear antenna ( radio and crap 1980's mobile phone retrofit kit )
Repair on all dents and scratches
Full de chrome
Fit front fog lights
Re furb of both front wings
Finished off with full respray...
Other work
Weld in cage. Tagged to a and b posts
Strip interior
Racing steering wheel
Be-spoke Central control panel
Push button start
Stack oil pressure gauge
Bucket seat
Full harness
Green wheels (BBS)
Front brake up grade with vented and slot discs. Running red stuff pads
Lowered suspension
Rear axle strengthen
Rear trailing arms strengthen
New rear wheel bearings
Rear brake disc conversion from drum
Rear poly bushes
Full adjustment rear axle kit fitted
Auto to manual gearbox conversation
I could go on and on but will stop their as pictures are more interesting
Before. This I think was the day I purchased it
During body work
After ( nearly finished ) after painting
Needs probably another 10 ish hours to get it ready for the road
Jobs left to do
Expel film cover the front valence to stop stone chips
Get the side door trims and new is front spoiler painted and fitted
Service as sat for 7 years and has not moved (apart front in and out of garage)
Finish off rear axle work and rebuild
MOT
The plan now is to finally drive it over the remaining part of the summer and then in winter rip the drive line out and install something a little more potent.... Will keep the post upto date with progress
