Hi guys,
Buying a 1990 320ISE and the guy says it does not have central locking, however it is so well equipped with every option other than cruise, I find this unlikely. So does it have central locking? And if so is it common for it to stop working?
Does it have central locking?
Vincent97
E30 320ISE Saloon
VW Golf GTi (Mk3)
VW Golf GTi (Mk3)
darkchild
IIRC all UK E30s from 1988 onwards had central locking though you could delete it as an option if you wished.
Locking faults are reasonably common - have a look in the Wiki.
- E30 Zone Meets/Events Team
There are a LOT of inaccuracies in that article, however, the page dealing with locking problems is more accurate: http://www.e30zone.net/e30zonewiki/inde ... g_problemsRav335uk wrote:http://www.e30zone.net/e30zonewiki/inde ... al_Locking
The red/black wire mod. will cure 2/3 of locking problems, but should be done anyway, even if it not the cause of the problem.
daboy3000
Does anyone have more detailed instructions for doing the mod on a cab, pref with pics?
Find the three red/blacks going to the back of the A pillar plug, looking through the speaker hole. Cut them all away from the plug, and solder them together.daboy3000 wrote:Does anyone have more detailed instructions for doing the mod on a cab, pref with pics?
Don't confuse the one red/brown for a red/black.
