Just wondering.. I have a 320i with no abs installed but I will be installing 51mm strut housings that fit abs sensors..
Do I need to legally fit abs if swapping to a m52 or can I blank it?
How hard is it to just wire it in? (I would prefer to have abs)
Do I need abs on m52 swap
I a few months from starting the build so no worries about the abs loom. Thanks for the info guys.
Also the last thing is when fitting the m52 do you need to run new clutch lines for slave and master or will the slave be in the same place as before or even closer so you just have to modify the existing cable?
- Contact:
If you really want ABS then your better off fitting the later E46 system, its so much better than anything else. I have it on my track car see here - http://www.e30zone.net/modules.php?name ... &start=150
Whats the procedure if I dont want abs? Can I actually remove the abs pump off the m52 engine? Sounds like it would make life easier regarding fitting the m52 ait filter housing instead of a k&n cone filter
