BMW steering rack tool
BMG
Post Fri Feb 12, 2016 10:58 pm
I fancy having a go at rebuilding my M3 rack , but it seem a special tool is need to fully disassemble which I can't find in the UK.
There's a couple of places in the US that sell but which won't ship to the UK and one that does but wants $80 post.
Does anyone know if it's still available at a dealer here or any places here that sell it I've missed, or anyone have one they've used and don't need and want to sell.
This is the part http://www.zdmak.com/go/PROD/BMW3031
The BMW part number might be 32 1 110
Jesus325iTouring
Frog freak !
Frog freak !
Post Fri Feb 12, 2016 11:01 pm
Sending shit anywhere is always tricky :wink:
BMG
Post Fri Feb 12, 2016 11:19 pm
$30 tool - $80 post and then into import tax and rip off ParcelForce charges.... Even allowing for BMW UK's inflated price, must be cheaper if available.
Opps, just noticed the unfortunate typo...
Post Sat Feb 13, 2016 12:13 am
I'll let you know tomorrow.
jimmyspeed
Post Sat Feb 13, 2016 7:47 am
It's hard to see in the picture but it looks like a motorbike Spring adjuster tool could work.
BMG
Post Sat Feb 13, 2016 9:52 am
This is the tool
Cypriotgeeza
Post Sat Feb 13, 2016 11:34 am
BMG wrote:This is the tool
Go to a machine shop with that pic..dimensions from the rack and get one made 8)
Then when your done with it sell it overseas for £30 and charge £80 for shipping :snigger:
Done deal 8)
Check my M30 build threads:
HairyScreech
Post Mon Feb 15, 2016 10:44 am
Yeah make one is your best bet. It's not really a complex tool.
Yeti
Post Mon Feb 15, 2016 4:20 pm
why dont you try a c spanner?
HairyScreech
Post Mon Feb 15, 2016 5:01 pm
Its the wrong way, the teeth on the C would need to be a 90 degrees to the C spanner. I don't think you would get onto it properly with a normal C spanner.
Post Mon Feb 15, 2016 5:23 pm
BMG wrote:I fancy having a go at rebuilding my M3 rack , but it seem a special tool is need to fully disassemble which I can't find in the UK.
Just checked and its NLA.
DHFiS
Post Mon Feb 15, 2016 8:48 pm
BMG
Post Tue Feb 16, 2016 1:13 am
Thanks, I did check today with Cotswold and heard the same.
BMG
Post Tue Feb 16, 2016 1:18 am
Not sure if its wide enough. It needs to sit around the tube of the rack.
Was wondering how much to get it made , but then is it worth the bother ? Probably won't come in much cheaper than getting mugged on the post and import duty and charges.
Post Tue Feb 16, 2016 8:22 am
You could make one of those on your drive with a grinder! The rack is approx 22mm I believe, measure it and buy a crowfoot spanner like this http://www.ebay.co.uk/itm/TOPTUL-19mm-3 ... SwX~dWsdZ1
Then just grind it up :)
HairyScreech
Post Tue Feb 16, 2016 1:40 pm
Possibly easier to just weld two tabs onto a large spanner?
Post Tue Feb 16, 2016 2:12 pm
Parallel punch and a hammer.
