standard wheel sizes
sheldo
Post Sun Feb 05, 2006 7:10 pm
What size are the standard 15" bbs wheels on my cab? Id go and check but the cars 30 miles away at the mo.
Just wondering if they are 6.5 wide or smaller?
Zayyan
Post Sun Feb 05, 2006 7:13 pm
7.
sheldo
Post Sun Feb 05, 2006 7:18 pm
i was looking at some BBS split rims but they are only 6.5's what do you think?
will they be ok?
Kos
Post Sun Feb 05, 2006 7:27 pm
if i'm correrct, you are looking at som bbs RM's, 6.5x15 if they were off a golf, they normally wree, the et will be 30, which wont look right. the will sit in the archers too much, but you could alway buy new lips and make them 7.5 or 8 or what ever you want really!!
sheldo
Post Sun Feb 05, 2006 7:33 pm
they reckon the et33. Still not look right?
Kos
Post Sun Feb 05, 2006 7:37 pm
correct, they will sit even closer in the wheel arch clost to the calipers and suspension legs, with 205/55 tyre it may catch. you will have to run a lower profile possibly and maybe 5mm spacers on the front.
sheldo
Post Sun Feb 05, 2006 7:44 pm
ok m8 thanks for the info
m3evo
Post Sun Feb 05, 2006 8:00 pm
Hi Sheldon, Those wheels are exactly the same as the ones i had on your car, but mine were 8" rims and there were no clearance problems, Hope this answers your question matey, cheers Dave
Kos
Post Sun Feb 05, 2006 8:05 pm
what tyre did you use?
mate had a set which were 8" and 9 " had to stretch on 195/50 on the front
m3evo
Post Sun Feb 05, 2006 8:45 pm
Hiya Kos, 205/50/15 toyos front and back
sheldo
Post Sun Feb 05, 2006 9:44 pm
apparantley this guy can change the beds? to make the wheels 7.0, 7.5, 8.0, 9.0. Is this what i need to have done to these wheels and if so what size beds should i go for? [/list]
Kos
Post Mon Feb 06, 2006 12:36 am
sheldo wrote:apparantley this guy can change the beds? to make the wheels 7.0, 7.5, 8.0, 9.0. Is this what i need to have done to these wheels and if so what size beds should i go for? [/list]
lops are about Ԛ£100 each, then you gota account for bolts, Ԛ£1 each, 35 per rim
it can get expensive
8 all round will be ok, any more you may have to roll arches if you lower the car
Kos
Post Mon Feb 06, 2006 12:37 am
m3evo wrote:Hiya Kos, 205/50/15 toyos front and back
good man, cheap and chearfull size!!
he'll need that if he widens them with new lips and bolts!!
