bab-91 wrote:![]()
( < EDIT: What an unfortunate selection of smileys)
bab-91 wrote:![]()
cheers bossImysE30 wrote:Look forward to the feature, credit to you and those who helped build this fantastic machine![]()
Yep and that's a car I've seen a lot off. .ImysE30 wrote:Studio Incar did Nick's M3, their work is amazing
#matgateNobby_N wrote:Rat shit will be so impressed when hes sees those beautys
When will this heap of shit appear in Max Power?Kos wrote:So, another update (even though the work was done ages ago
the audio
I had the Front Speakers are 6.5" Hybrid Audio Imagine Component set, installed in some bespoke builds, they were initially powered by a JLAudio amp.
It peaked up so now they are powered by a Hertz HDP-4 1000W RMS digital amplifier in Active format. This means every speaker has its own power supply, no crossovers needed (all controlled by the Bit10)
The door cards stripped (this photos sent to me by the installers. No may would take this much care when taking things apart would they) and they were sound deadened
in the back i had 2 10' JL Audio W6's powered by a JL1000/1 V2 amp in a ported box, It was low wobbly bass and i wanted it to be tighter and more controlled
So, had sealed box made from marine birch ply and and the subs now fire up to the rear shelf. The box is solid mounted with steel rods (you can make them out in the photo), No energy loss and no chance of it moving
the box is not a a think of beauty, its pure function. It is also cross braced internally
you can make out box supports going to the rear shelf
and the new cover panel. we could have moved it further back but that would have meant making a new floor. The space left is more than ample for me
I also installed an audition Bit 10 sound processor. It takes the singles from the HU and turns it digital, it infects make the HU redundant bar as a sound source and for volume control. Due tot his at some stage i will install a period correct HU
The sound, it warm its clear. you are not killed by harsh trebles from the tweeters, the bass will upset you if you want it to but i don't. its just there when i want to listed to some hip hop.
its more than loud enough but that was not the objective here. the objective was SQ and it is happy playing some opera and its happy playing rock. all it needs is a slight adjustment for the bass from time to time and thats it.
here's a link to Studio InCar who did the work. its to their website blog and worth a read
http://www.studioincar.com/blog/
