E30 M3 V10
KW355
Post Sun Dec 27, 2015 4:05 pm
DanThe wrote:I was going to try this one as it has a proper 2 pin connector and is 0-170 which is what the gauge shows http://www.ebay.co.uk/itm/180847879900? ... EBIDX%3AIT
Dan,
As it is two pin it probably is insulated earth, i.e. one pin connected to earth and the other one to the gauge, not a problem but it means an extra earth wire must be provided.
The one I ordered is single pin and earths through the sender body to the car's oil filter housing.
Cypriotgeeza
Post Sun Dec 27, 2015 4:13 pm
looks like it was supposed to be there all along! :thumb:
Check my M30 build threads:
Post Sun Dec 27, 2015 5:47 pm
Dan,
Yes I realise that, I just prefer the 2 pin 'click' connector as used on E30's from factory due to OCD reasons :D
KW355
Post Sun Jan 31, 2016 2:03 pm
I have just finished a rear suspension refurb on the M3.
I wanted to strip it down to check for wear and tear from age and V10 abuse and replace / strengthen as necessary, I was pleasantly surprised, the rubber bushes were a bit aged, the wheel bearings were slightly noisy but the driveshafts seemed o.k. so I decided to just refurbish.
It took a day to strip it all out, I think I got off lightly with seized bolts etc as most of it had been taken apart by Glenn during the initial rebuild.
I opted to take discs, calipers and the diff off in situ, the diff is very heavy (35kg ?) this left the beam and trailing arms which are relatively manageable
I removed the trailing arm bushes with a version of the wiki diy removal tool, I used a 30mm deep reach socket instead of the pipe as I had one to hand. they came out easily after a warm with the hot air gun.
If you are doing your beam bushes it is so much easier with one of these;
The beam bushes also came out easier with a heating, I believe this tool can remove and install bushes in situ.
some of the bits for the refurb;
I opted to go for satin black powder coating, I think it came out really well;
I left some old bolts in to protect the threads and cut some 10mm plywood discs to protect the bearing housings.
The diff had a slight oil leak, I believe it was from the drain plug, I took the cover off, cleaned the diff out, changed the gasket, speedo sensor retaining plate and the plug crush washers. It was then painted.
Before reassembly I changed all the hard rear brake lines, flexible Black diamond brake hoses and the main fuel line including mounting clips. The fuel / brake line clips were mostly seized, I had to drill and tap the old screws out, not a nice job !
I started reassembly by fitting the beam complete with Powerflex bushes, I then fitted the trailing arms, diff and brakes (which have been refurbished previously )
The wheel bearings were changed ( SKF ) and the driveshaft c.v's were cleaned out, checked, regreased and fitted with new GKN Lobro c.v joint boots from ecp;
http://beta.eurocarparts.com/ecp/c/BMW_ ... 81e&000445
Most boots are too big for the wheel side, they rub on the shock absorber. The diff side kit fit fine apart from the bolts which had no tensile markings on them, I brought some proper ones, the people who did my propshaft recommended 10.9 tensile strength for drivetrain bolts.
For the wheel side I removed the rubber boot from the kit, it has the correct circular seal to fit on the existing c.v metal cover. Basically I paid £19.80 for the kit and only used the rubber boot for the wheel side, still cheaper than the £60 BMW wanted per boot kit.
The diff was filled with 1.7 litres ofCastrol Syntrax 75w 140 lsd oil.
I also fitted a temperature sensor to the diff as my vdo oil temp gauge was not being used because the Awron dash vent gauge provides this info.
I used an e30 engine coolant temp sender as this over reads by about 50% on the vdo gauge, it also allows the fitment of the correct 'click' type oem plug which should satisfy Danthe's oem plug fetish !
The over read is required because the vdo gauge does not start reading until 60 degrees c. After a 30 mile test drive the diff temp was showing 65 to 70 degrees c so about 40 degrees actual which is in line with the gearbox which runs at about 50 degrees c
I reckon the cost for parts is about £500 which includes the powerflex, powdercoat, boots, brakeparts etc and all new clips, bolts and fittings.
A few shots of the car as it stands;
Mr-Lachs
Post Sun Jan 31, 2016 2:13 pm
Just looked stunning up in the dictionary and there was a photo if your car!! :-)
Mr-Lachs
1988 BMW E30 325iSE Auto, 4 Door, Lachs Silver (Fair Weather Machine)
2012 Vauxhall Insignia 1.8 Exclusiv, Technical Grey, (The Daily)
Cypriotgeeza
Post Sun Jan 31, 2016 2:28 pm
Top work!
Love this car :drool:
glenn
Engine Transplant Services
Post Mon Feb 01, 2016 7:41 am
brilliant work keith.
its definitely in good hands
8)
MPOWERCRAZY
Post Mon Feb 01, 2016 11:17 pm
beautiful car mate :)
Back Again From The Darkside Of Doing E36'S :mad:
Back With 2 E30 Projects :cool:
Post Mon Feb 01, 2016 11:34 pm
Some good work going into this.
Good to see the continual development of an awesome machine!
glenn
Post Tue Feb 02, 2016 4:07 pm
bss325i wrote:Some good work going into this.
your right barry,
I couldn't be happier, that keith bought it. he's doing it proud.
a car with a major engine conversion like this, couldn't of been sold to someone who didn't know one end of a spanner from the other.
when I sell the e46, I hope it goes to someone similar. :D
Post Tue Feb 02, 2016 4:45 pm
I would love the E46!
Contact me when you're ready Glenn!
tomson
Post Wed Feb 03, 2016 7:41 pm
I remember this car when Paul owned it, 'twas a right old sorry state back then. Glad to see the change!! :D
Post Sat Feb 06, 2016 3:43 pm
Stunning :cool: :cool:
KW355
Post Mon Feb 08, 2016 5:26 pm
Thanks for the comments :D
KW355
Post Mon Feb 08, 2016 10:02 pm
My vid seems to have disappeared, here it is again.
http://vid292.photobucket.com/albums/mm ... 49jzac.mp4
glenn
Post Mon Feb 08, 2016 10:25 pm
KW355 wrote:My vid seems to have disappeared, here it is again.
I still enjoy watching this vid, keith
makes me chuckle, brings back good memories 8)
jimbom30cab
Tech 1 freak
Post Mon Feb 08, 2016 10:32 pm
Flippin awesome !!!
jkm3
Post Tue Feb 09, 2016 10:34 pm
Bloody hell, that's quick, proper quick!
fixedwheelnut
Post Tue Feb 09, 2016 10:48 pm
Love the number plate, The number of the Beast :D
P_VIDDY
Post Tue Feb 16, 2016 8:33 am
proper job on the rear axle. Nice work
KW355
Post Mon May 02, 2016 3:00 pm
I have not done an update for a while, mostly because I have not done anything to the car apart from polish and drive it :D
The car continues to surprise fellow road users and myself sometimes, I booted it the other night after not driving it for a bit and my first thought was that the front wheels were coming off the ground :o
Most of the time I drive it in 400 bhp mode but sometimes you just have to press the 'power' button to get the full 500 bhp !
I have been looking in to the front suspension, it is very hard, I sent the springs off to Gaz to test them and they were 650lb.
After a discussion with Gaz they suggested 400lb for a standard road car and 450lb for my car to compensate for the V10.
The ride is still hard but a bit more compliant, I will try changing the adjustable damper settings.
I got a bit bored over the bank holiday and decided to refurb the headlight brackets, they were a bit tatty and all the adjusters were seized. fortunately they came apart without breaking.
Image 8O
I am looking forward to the show season and plan to attend as many as possible.
MPOWERCRAZY
Post Mon May 02, 2016 5:58 pm
always love the updates on this thread, they get better each time :) looking good mate!
KW355
Post Wed Jun 22, 2016 3:46 pm
The car started running a bit strange recently, I looked on the Awron vent gauge and noticed that the fuel pressure was wrong and the air fuel ratios were out on both banks.
I decided to change the in tank fuel filter / 6 bar pressure regulator first which I had grafted in to the e30 tank ,
A bargain at £172 from BMW, unfortunately it didn't solve the problem but it did retain the fuel pressure better when the engine was switched off. I then swapped the power to the in tank pumps over ( one pump runs at variable speed @ 3 bar and the second comes in at cold start and high rpm ) this made no difference as well.
Next was a phone call to Glenn's one stop V10 shop for one of these;
This is the fuel pump module which is controlled by the engines d.m.e. fortunately it solved the problem.
I have had the car on the ramp recently and done quite a few jobs, polybushed the front end, wrapped the exhaust with heat bandage, changed the clutch pipes, cleaned the injectors and reset the wheel geometry amongst other things.
I decided to treat myself to some recaro sportster cs seats, they are out of a corsa vxr and are black nappa leather. not exactly period correct but easily removable.
At first it looked like an easy job as the seat rail centre line was only 5mm different to the e30 floor bolts, unfortunately the seat rails are offset 30mm from centre so I had to fabricate some brackets and remove this bracket;
I also removed the 10mm spacers from the bottom of the seat rails to get the seat as low as possible.
I took the car to the Santa Pod show last weekend, it was on the e30 zone stand and it generated the usual interest.
Fal_325i
Post Wed Jun 22, 2016 4:16 pm
Wow, the seats actually work, even though they are from a Corsa :)
ah
Post Wed Jun 22, 2016 6:18 pm
Love the plate,and I bet it will be!
Post Wed Jun 22, 2016 6:34 pm
Nice Keith.
Seats actually looked right at home. :cool:
glenn
Post Wed Jun 22, 2016 8:18 pm
I miss this car so much....
once the E46 sells, i'm building another E30 M3 V10
MrGCC
Post Sat Jun 25, 2016 6:17 pm
Good lord this car is amazing! Just a beautiful build with so much detail. :cool:
KW355
Post Sat Jun 25, 2016 6:35 pm
MrGCC wrote:Good lord this car is amazing! Just a beautiful build with so much detail. :cool:
Thanks and welcome to the zone, I see you are from God's country a˜€
SasG
Post Sat Jun 25, 2016 9:10 pm
these seats....... amazing... you've really made me consider something similar... great job
KW355
Post Wed Jun 29, 2016 8:21 pm
SasG wrote:these seats....... amazing... you've really made me consider something similar... great job
I highly recommend these seats, they are really comfortable.
SasG
Post Wed Jun 29, 2016 10:44 pm
Im already searching lol
s62
Post Sat Jul 23, 2016 12:53 am
Keith - the Mishimoto radiator, is it the X-line or the normal E36 M3 rad? I guess from the pics it´s the normal one.
Have you driven the car hard for sustained periods on a track? If so, water temps ok?
KW355
Post Sun Jul 24, 2016 8:17 pm
s62 wrote:Keith - the Mishimoto radiator, is it the X-line or the normal E36 M3 rad? I guess from the pics it´s the normal one.
I have not done a full track day in it, just a few laps but it did not overheat, it will sit all day in traffic in the middle of summer and has never overheated even when driven hard.
It is the 'standard' Mishimoto e36 M3 rad, the thicker one would not fit
s62
Post Sun Jul 24, 2016 10:26 pm
KW355 wrote:I have not done a full track day in it, just a few laps but it did not overheat, it will sit all day in traffic in the middle of summer and has never overheated even when driven hard.
Ok, then I´ll use the standard one also.
The gas pedal - is it one from the E46?
