More questions - thought I'd post them here to avoid starting another thread.
I'll be replacing the M52 oil filter housing with an M50 one so I can use a filter cap oil cooler takeoff (Rallyroad). Does this mean I also need to use an M50 alternator, PAS pump and auxiliary belt? Are the belt tensioners the same?
Also, does anyone have any experience with uprated E30 clutches? I'd like to keep my M20 flywheel/starter and ZF gearbox combination, so any recommendations for a beefier M20B25 clutch would be welcome.
Thanks again guys
