Will lowering by 35mm make any difference to the 4x4 arch ga
zortonesta
Post Sun Jan 10, 2016 4:45 pm
Hey, looking to drop my car a bit as the arch gap right now is huge.
Currently on 14" bottletops but will be getting some 15"s pretty soon.
I've found some H&R springs (35mm lowering kit) for a decent price and my plan was to just install these and keep the stock shocks until they give out, but I'm wondering as the gap right now is so big is a 35mm drop really going to make much difference?
Cloggy Saint
Post Sun Jan 10, 2016 4:47 pm
At a guess I'd say it will make 35mm difference.
zortonesta
Post Sun Jan 10, 2016 4:54 pm
I was never good at maths.
I read that you are to expect some 'settling' so I guess what I'm asking is does 35mm actually equate to 35mm in the real world or is it more?
Cloggy Saint
Post Sun Jan 10, 2016 4:56 pm
It may take a while to settle to -35mm and it may not be exactly -35mm when it is settled but it should be there or thereabouts.
Post Sun Jan 10, 2016 10:03 pm
zortonesta wrote: and keep the stock shocks until they give out,
If they're the originals, they most certainly already have.
zortonesta
Post Mon Jan 11, 2016 9:22 am
Cheers guys, I'll have to go for some new shocks too then and put the rim replacements on hold!
Post Mon Jan 11, 2016 10:27 am
Combine your H&R springs that you've found with some Bilstein B4s, check out the front control arm bushes and rear subframe support bushes, and replace if necessary and you'll find out what you've been missing as regards E30 handling and ride quality.
parakeats
Post Mon Jan 11, 2016 11:27 am
sorry to hijack, but do you recommend the H&R with B4 or B6 Bilsteins? or is that application dependent?
zortonesta
Post Mon Jan 11, 2016 12:58 pm
Thanks Brianmoooore, top advice there.
zortonesta
Post Mon Jan 11, 2016 1:13 pm
I've found the H&R sport lowering springs plus front and rear Bilstein B4 shocks, all in for £264.
Does this sound like a good deal gents?
Labour will have to be on top of this of course, when I've collected more sheckles to have it done.
pauljsc
Post Tue Feb 16, 2016 10:16 pm
Where did you find these springs and shocks for that price?
parakeats
Post Wed Feb 17, 2016 11:42 am
I bought for a very similar price form demon tweeks, but compare part numbers before purchasing springs as when I looked they had 4 & 6 cyl springs listen for my 4 cyl
