Yes that belongs to Chow.E30Jeevs wrote:Chow 92 is your the white tech 2 on a g reg ? With red leathers? Any progress on the car?
Alpina c2.7 advice
Gert_8
What's the difference?
Usual Alpina changes tended to be a slightly larger bore "tuned" engine (no visible difference because it cannot be seen externally) altered/improved suspension (slight difference to stance) visible externally, and tacked on bits to bodywork and some internals...visible and not so.
Other than that, the same bodywork.
The M3 was a radically different car to the regular E30 to the extent that very few parts are interchangeable. It remains the most successful touring car ever.chow92 wrote:Andyboy so the e30 m3 would you class that as a slightly better e30 the simple fact is the alpina c2.7 are rare highly desirable compared to the 325i sport and the better car theirs a reason their ££££ compared to 325is
The C2 2.7 is a warmed over 325i with some nice wheels and trinkets. It was quite a nice thing when new but nothing a Sierra Cosworth with a touch more boost couldn't sort out. Or a Renault 21 Turbo. I believe a Montego Turbo had the legs on it as well.
No they didn't. It was stroked not bored. And a genuine block and head is stamped by Alpina.Gert_8 wrote:
Usual Alpina changes tended to be a slightly larger bore "tuned" engine (no visible difference because it cannot be seen externally).
Gert_8
Yes, but you're missing the point.B7 wrote:No they didn't. It was stroked not bored. And a genuine block and head is stamped by Alpina.Gert_8 wrote:
For the street it more or less is about straight line speed. M3 vs Cossy it really boils down to the turbo lag of the cossy and length of the road imo??
Im aware as touring cars, they was in different classes and the M3 still managed to keep up with the cossies as the Ford's handling, overall chassis, reliability and even managing to put all its power down wor ked against it.
C2 2.5 is both bored and stroked to give a displacement of 2554cc and In the case of B6 it was entire engine swap. Lot more R&D and work went into it than meets the eye.
Alpina are highly unique cars and no two cars were identical so worth their price tags imo.
I'm no racer, seen people be run over 3x in my time to do something so stupid as that nor is the terrain ideal for racing in Wycombe, not a single straight level road around these ends!!DanThe wrote:If street racing through high wycombe is your bag”¦
Street racing is mostly done on dual carriageways or small stretch of straight roads by people... who does 80mph going round a bend??
'fraid not.87mtech27 wrote:C2 2.5 is both bored and stroked to give a displacement of 2554cc and In the case of B6 it was entire engine swap. Lot more R&D and work went into it than meets the eye.
the C2.5 was purely a cam, ecu and exhaust on a standard 2.5 to bring it to around 192hp. That conversion was also available with no other Alpina trinkets and was known as the Alpina sport pack. Barry had a convertible with that very conversion. Bore and stroke was standard 2.5.
The C2 2.7 was a standard 2.5 block with a TD crank which had a longer stroke. it used standard 135mm rods with custom Mahle pistons with the gudgeon pin further up the piston to ensure TDC remains and a flatter top. It shared exactly the same bore as a 2.5. The 2.7 was achieved with swept volume and not by enlarging the bores. It then had a head that was worked by the Alpina guys which took meat away from the combustion chambers and moved the compression from the piston crown to the chamber. The exhaust ports were tickled to perfect round (standard heads always had a slightly egg shaped port), the inlets were mildly tckled we think but never polished or enlarged. It then gained a bespoke ECU, exhaust and cam to complete the package.
There are a few of us with these engines and have had them apart numerous times.
Trev, they did do a C2 2.5 as well as a C2.5.B7 wrote:'fraid not.87mtech27 wrote:C2 2.5 is both bored and stroked to give a displacement of 2554cc and In the case of B6 it was entire engine swap. Lot more R&D and work went into it than meets the eye.
The C2 2.5 was based on the 323i and was 2554cc as opposed to the 325i's 2494cc.
Felix's old turd was one of those early ones.
C2 2.5 was based on the 323i before BMW released the 325i (on which the c2.5 was based) with its 2494cc motor. From what I've read the C2 2.5 used eta block (84mm bore) with 323i crank (76mm or 76.8mm stroke) with custom mahle pistons.. I'm guessing they did the standard port and polish with cam etc. Power was rated at 190 bhp. C2.5 was rated at 185 bhp.
Well thats rubbish.87mtech27 wrote:therefore M3 handling is of no use off track
C2.5 was 192bhp.87mtech27 wrote:C2 2.5 was based on the 323i before BMW released the 325i (on which the c2.5 was based) with its 2494cc motor. From what I've read the C2 2.5 used eta block (84mm bore) with 323i crank (76mm or 76.8mm stroke) with custom mahle pistons.. I'm guessing they did the standard port and polish with cam etc. Power was rated at 190 bhp. C2.5 was rated at 185 bhp.
Topblag
I'm restoring mine and may well have the head off it soon. I'll take some pics for the wiki.87mtech27 wrote:C2 2.5 is 185bhp then? Shame no one has opened and documented the c2 2.5 engine to see how it was built... Most likely 130mm rods, flat mahle pistons and guessing the same head as c1 2.3.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
What year is your car Collin?Topblag wrote:I'm restoring mine and may well have the head off it soon. I'll take some pics for the wiki.87mtech27 wrote:C2 2.5 is 185bhp then? Shame no one has opened and documented the c2 2.5 engine to see how it was built... Most likely 130mm rods, flat mahle pistons and guessing the same head as c1 2.3.
That would be interesting readTopblag wrote:I'm restoring mine and may well have the head off it soon. I'll take some pics for the wiki.87mtech27 wrote:C2 2.5 is 185bhp then? Shame no one has opened and documented the c2 2.5 engine to see how it was built... Most likely 130mm rods, flat mahle pistons and guessing the same head as c1 2.3.
Anyways jamie079 regarding Your choose when it comes to getting your c2.7 as you can see their are some mixed reviews and feelings between the fellow members on here. Personally I would just go with your gut and buy one for you if u really want one or put another 10k in to your budget and get a e30 m3 nd lose the straight six lol. When it comes to the cosworth yes the cossy with a few twicks and little money trown at it is a way faster car and if speed matters why are we driving e30s for ?
That's right but looking at the OP's original post, I took it that he was looking at later cars.bss325i wrote:Trev, they did do a C2 2.5 as well as a C2.5.B7 wrote:'fraid not.87mtech27 wrote:C2 2.5 is both bored and stroked to give a displacement of 2554cc and In the case of B6 it was entire engine swap. Lot more R&D and work went into it than meets the eye.
OP I don't think you can't be too picky with regards to colour or spec when it comes to choosing a Alpina C2 2.7 as most likely none will meet your criteria spot on. Just be sure it's genuine with paperwork to prove and go from there.
M3 is a totally different car to the 6 pots, basically its a race car sold to the public so BMW can go racing unfortunately for car manufacturers at the time they had to build and sell 5000 identical cars and 500 examples of any evolution if changes where made.
It all comes down to your budget at the end of the day to what you want.
I would rather prefer unmolested Sierra RS Cosworth (3Dr not a fan of sapphire) with 204bhp than one with increased boost and silly 3" exhaust.chow92 wrote:When it comes to the cosworth yes the cossy with a few twicks and little money trown at it is a way faster car and if speed matters why are we driving e30s for ?
M3 comes alive at 4k+ revs and cossie is similar due to turbo lag but I'd imagine when it comes on you would really feel the kick
Would love both in my imaginary dream garage
Gert_8
I know I'll get abused for the following, but the cosworth is an ugly dog of a car compared to any E30
steve_k
- Contact:
which one? 3 door? saff? or escort??Gert_8 wrote:I know I'll get abused for the following, but the cosworth is an ugly dog of a car compared to any E30
Topblag
1988 on an F plate.bss325i wrote:What year is your car Collin?Topblag wrote:I'm restoring mine and may well have the head off it soon. I'll take some pics for the wiki.87mtech27 wrote:C2 2.5 is 185bhp then? Shame no one has opened and documented the c2 2.5 engine to see how it was built... Most likely 130mm rods, flat mahle pistons and guessing the same head as c1 2.3.
Gert_8
Sierra 3 door. Hideous! the Escort was very nice!steve_k wrote:which one? 3 door? saff? or escort??Gert_8 wrote:I know I'll get abused for the following, but the cosworth is an ugly dog of a car compared to any E30
Then yours will be the 325i based C2.5 spec engine with just a cam as the only internal difference to a standard 325i engine, not the 2554cc version with custom Pistons, eta block and 323i crank.Topblag wrote:1988 on an F plate.bss325i wrote:What year is your car Collin?Topblag wrote: I'm restoring mine and may well have the head off it soon. I'll take some pics for the wiki.
Weight is always dependant on the options spec of the car so don't take that 200kg difference as gospel.
