Help with spark plugs
Porthos
I am in the US but, I own a UK market 318i Touring with the M40B18 engine in it. I bought some NGK BPR6ES spark plugs to replace the ones that are in the car now because I can not tell when the last time they were done. First, I can not get the 19mm socket into the plug hole it is too big(that's what she said!). Is there a special socket? Second, I just wanted to make sure that they plug I had would fit the 19mm socket and the plug is larger than the socket. So I am lost on what should be a very easy task and would like some help.
jimmyspeed
Check your tool roll in the boot/trunk - there should be a long hexagonal tube which pairs with a grey handled bar that slots in to change your plugs. If not you can buy special tools
maxfield
It should be a 21mm socket you need.
You can get spark plug sockets from most motor factors which are reasonably thin walled.
Porthos
Thanks for the help I will go look right now and let you know.
Porthos
So I went and looked for the tool kit. Now this car is 25 years old. It has 25 years worth of service records, the original first aid kit, the jack, and I am the 2nd owner but, it does not have the tool kit.
The 19 won't even fit into the spark plug whole so I am not sure going bigger will be better.maxfield wrote:It should be a 21mm socket you need.
maxfield
Spark plug sockets are thin walled to fit into tight spaces. Have you tried a socket on a new plug so you know the size?
They are either 21mm or 16mm (bar some new BMWs which are 14mm double hex) and I'm pretty certain they are 21mm.
Porthos
Ya it has to be a 21mm because I read on another website it was 19mm and that definitely does not fit.
Porthos
So I can't find a tool kit or that specific tool to remove them. I am new to E30s and especially the touring model can anyone tell me where in the car I should find the tool kit.
jimmyspeed
no worries - your specifically looking for this
It should be in a tool roll in the rear pods - i would check the spare wheel area as well. Although it sounds although yours is missing.
If you can't find the tool buy a socket one like maxfield said or get one like this -
summit racing or jegs will have tonnes
reggid
spark plug socket is a deep socket and correct size is 13/16" or 21mm
E30 325is with M20B31
Porthos
I understand that but, it will not fit into the spark plug hole.reggid wrote:spark plug socket is a deep socket and correct size is 13/16" or 21mm
jimmyspeed
[quote="maxfield"]Spark plug sockets are thin walled to fit into tight spaces.
reggid
yeah how about buy a dedicated spark plug socket. A generic one fits fine....
jimmyspeed
Porthos wrote:I understand that but, it will not fit into the spark plug hole.reggid wrote:spark plug socket is a deep socket and correct size is 13/16" or 21mm
Porthos
I will get one in the morning.
Porthos
This is what I am working with \
Porthos
I will give that a try when it is not raining. El Nino has officially arrived in Southern California.
fixedwheelnut
This is what you need 16mm thin wall 3/8th drive plug socket
http://www.justoffbase.co.uk/Spark-Plug ... oCgYDw_wcB
Porthos
If my 16mm does not fit I will give that one a go.
Porthos
Ya, it is the 16mm. Going to go look for the correct plugs.
Porthos
Pretty sure I ordered the correct spark plugs this time. SHould find out in a couple of days. Never had this much trouble with such an easy piece of maintenance.
Porthos
Finally got the correct plugs and they installed beautifully, thanks for looking out W
illnz. I have some pics too. The ones in their were the Bosch ones which are a tad bit more expensive.
