Accelerator pedal removal
Benjer182
Post Thu Dec 31, 2015 11:16 am
I'm taking the carpet out of my car to clean it and check for any water leaks but I'm stuck on the accelerator pedal how does it come out, I don't wanna try and force it and break it
Thanks in advance
DHFiS
Post Thu Dec 31, 2015 11:31 am
There is a metal slot on the floor and the plastic tangs on the bottom of the pedal push onto it.
Benjer182
Post Thu Dec 31, 2015 11:45 am
Ok cheers so does it just pull up ? Or is it a slide to one side ?
blazed
Post Thu Dec 31, 2015 11:59 am
Unclip the top and pull up, you may need someone to press the tangs in so they don't break.
BMG
Post Thu Dec 31, 2015 12:00 pm
BenHar
Post Thu Dec 31, 2015 2:47 pm
If that's not in the wiki it should be.
I'll PM Grrr.
Ben
Benjer182
Post Thu Dec 31, 2015 4:30 pm
Cheers lads I sorted it out and the rust I found while I was there
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Jan 02, 2016 7:53 am
