Next logical step in the rebuild was to tackle the rear brakes.. Lately Ive done A LOT of brake jobs (M3, 320, mother's Acura, father's Ford, sister's Hyundai..) and to be honest the e30's brakes are quite a bit different.
I basically lived the FULL RANGE of human emotions fitting the rear LH parking brake and brake. With that done it took 10 MINUTES to do the RH rear brakes. That includes removing the tire and reinstalling it. Who can figure these things out? Not me..
In order not to bore you too much I will combine both to show the general gist of the thing so that anyone smarter than me (99.9% of you) will have an easy time of it.
First thing I did was grind clean the edge of the hub as it was a complete b*tch to remove the wheel with it painted - looks pretty but that extra 1/10th of a mm of paint makes a BIG difference...
Next I spent a good while finding all the parts Id purchased years ago when I started this insane project..
Here is the parking brake refurb kit.. The springs and adjuster are purchased separately, the pads come as a complete set (for both wheels). The piece on the bottom is the expanding lock - it connects to your parking brake cable and I ordered a new one as I had one missing. Each rear wheel will need what you see below (disk brake cars!):
IMPORTANT: Note the indents on the pads..the large ones go towards the top the narrow ones towards the bottom as shown..
The RH rear wheel will also need the brake wear sensor..
