Vanos seal change
I've done one and it was straight forward, if you search for dr vanos there are lots of online guides that walk you through the entire process.
There is another way of doing it which I will also try on my next engine and that is to undo the 5 or 6 10mm (from distant memory) bolts that hold the sproket onto the vanos housing and pull the housing off without disturbing the timing or cam set up. There is a thread about it on here but I'm not sure I bookmarked it.
- Contact:
Its the Monkey method, as the guy that posted the info on here first username is Monkey
Some pics in my thread here - http://www.e30zone.net/modules.php?name ... &start=625
