I'm close to pulling the trigger on one -
It's got 47k on clock, full dealer history and it's true genuine example.
Working on the figures but its up for 29,990 and I ain't paying that, closer to 25k is my budget.
What is an auc car pleasekieran325 wrote:It's a AUC car so all that's covered for 12months.
It's a scar being sold by a BMW main dealer that's out of the manufacturer 3 year warranty which means after and AUC check (Approved Used Car) it gets 12 months warranty.manse73 wrote:What is an auc car pleasekieran325 wrote:It's a AUC car so all that's covered for 12months.
Better off spending the dough keeping one of these in fuelkieran325 wrote:BMW warranty, comp cover is £1285 with £100 excess, Named cover £1065 and Driveline cover is £811.
Now that's the 1st price band for anything up to 60k.
Car with 60k and above is £3143 a year![]()
AKA p*ss*ng money away on a depreciating item. The SMG can also be a gearbox issue - pump, control unit.kieran325 wrote:BMW warranty, comp cover is £1285 with £100 excess, Named cover £1065 and Driveline cover is £811.
If that's all it's had then it's doing well for an E61!kieran325 wrote:Warranty work carried out -
44k Rear tailgate release
38k Horn
29k Grated noise from final drive - no fault found
11k Rear window washers, leaking pipe
10k Horn
That's from BMW.
I was going to suggest an RS4Gert_8 wrote:Audi R6 of course!
RS4 is = to three series and the RS6 is more your fiver.daboy3000 wrote:I was going to suggest an RS4Gert_8 wrote:Audi R6 of course!
Kieran can afford it!!daboy3000 wrote:True, but I was thinking of the original one from around 20 years ago. RS6's are much newer.
Think youve summed it up perfectly mate - youve got to be comfortable that youre putting £25k into something that you will hardly use, and which will depreciate hard and either you have to pay a fortune in running and warranty costs for something youre hardly going to use, or take a punt that the 4k a year you do wont cause a significant failure of some sort.kieran325 wrote:Fair comment Rob and something that's been playing over and over for the last few days.
When I say I'll do about 4K a year is because I run around in the 325 and M3 when the weather is good so the M5 would be used for weekends away and general long haul trips. I generally bum lifts to work or cycle as it is now so it would be used sparingly for short journeys.
I've longed for a juicy estate car for a while and this one crops up within a few miles from me that I'm liking, but I'm unsure now which way to go.
