My boot light stays on continuously even when the light switch is pressed, so I am presuming faulty boot lid light switch.
Anybody know if it is the same part as the interior light switch for the doors? Or specific part. Cant find it on realoem
Boot Light Switch
BenHar
Difficult to see how it can fail 'on'. Take it out and check it over, along with the wire to the lamp.
RobWill116
Thanks Ben.
The one fitted currently doesn't look like the one picture on realoem.
RobWill116
What would make it fail to switch off? I have held the switch pressed in for about 10 secs and still didn't switch off. Wire going to the lamp is fineBrianmoooore wrote:Difficult to see how it can fail 'on'. Take it out and check it over, along with the wire to the lamp.
BenHar
Pictures in there are not always accurate and there seem to be quite a few different part numbers depending on the age of the car.RobWill116 wrote:Thanks Ben.
As Brian says, remove and inspect yours.
Ben
RobWill116
I have removed the switch and the light stays on. I've took the lamp out at the moment so the battery doesn't get drained whilst its garaged up. Light wired up to constant feed instead of the switchable feed?willnz wrote:Remove the switch and unplug the wire from it without disturbing the wire as much as possible. Does the light stay on or go off?
The housing of the switch has a crack in it, no other obvious signs. Haven't tested the switch yet though, will do tonight
RobWill116
On the rear of the switch, should there be two connectors like the interior door switches? This only has one connector
What colour, and how many, wires are connected to the light. There's a remote possibility that an incorrectly fitted or faulty alarm is causing the problem.
RobWill116
Disconnect the LH brown/black. It probably goes to an an alarm.
Replace the bulb, refit the light and the switch, and see if it behaves then.
Wire on the far left is red/green BTW, not black. That's just an outer sheath.
RobWill116
Disconnected the LH brown/black - it now works as it should! Thanks.Brianmoooore wrote:Disconnect the LH brown/black. It probably goes to an an alarm.
Will disconnecting this may the alarm play up now though?
The alarm is already playing up if it's shorting this wire to earth.
Next stage is to remove the glove box access panels, find the other end of the same wire where it comes up from the sill area, disconnect it from the alarm, plug it back onto the boot light, and see if the light still switches off.
Might be worth inspecting the wire where it runs along the LH boot hinge first, to see if it has become trapped anywhere and is shorting out there.
