Hi All
I have just purchased a 2 door 320i, and want to do a 2.8 stroker turbo conversion on it.
Ive read the Wiki and it advises on:
m52b28 single vanos crank
m20b25 engine of course (pistons)
m20b20 rods
With this, the wiki says that compression ratio is about 9.75:1 - is this low enough for a turbo, or should i get a MLS gasket as well to drop it further.
Which turbo should i be looking at getting for around 400-500bhp and which cam is suggested.
Also, where can i get the spacer for - is there anyone on here that does it?
Q
Possible M20B28 Turbo build - collecting parts
Quaser
maggspower
- Turbo Farmer Tractor Driver
PMed
Contact: theengineshedonline@gmail.com
Lurch320i
I'm selling my turbo kit
Everything you need
Everything you need
motormanmick
Really good book to get, Maximum Boost by Corky Bell, well worth the read, helps you understand what's going on, design/testing/instillation and importantly detonation.
You will need a turbo capable of over 20 psi boost, to give you an idea, a good 2.8 stroker will yield around 210/220 bhp at atmospheric pressure which is 1bar or 14.7 psi. In a perfect world, if you boost by 14.7 psi you will double the volumetric efficiency of the engine and it will produce around 420/440 bhp, but when you compress air it heats up and expands, thus reducing pressure, hence the intercooler, if the intercooler is 90% efficient, then 90% of 14.7 psi is around 13.4 psi. Just to give you an idea, there is a lot going on. Ideal compression ratio for your project is around 8:1 or a tad more, trade off in low compression and big boost is size of turbo required and lag as a result, best get the book, I learnt plenty from it.
Lurch320i
Amen that book is good even if it is a bit oldmotormanmick wrote:Really good book to get, Maximum Boost by Corky Bell, well worth the read, helps you understand what's going on, design/testing/instillation and importantly detonation.
I spent many nights reading that as i was collecting parts
michael7s
get M50 as they are more capable of this kind of bhp.
I used to have m20b25, but now changing to m50b25 ith large holset turbo
Quaser
I already have an m50b28 turbo project going on in an e36 - the 320 I just got came about at a decent price - (£1800 with full adjustable billies, scorpion exhaust, 83 genuine miles and decent bodywork, a set of white returned bbs, and 17" Brock deep dish alloys)
Rather then have 2 m50/52 turbo projects, I decided to stick to the m20, although I am contemplating a m60b40 conversion instead - how difficult are they to turbo??
motormanmick
for anyone that would like that book, Maximum Boost by Corkey Bell, pdf link below
http://www.fusca.net/wp-content/uploads ... _boost.pdf
if your in the planning stages, it's a must read.
_Dan_
my clutch is for sale .. have a bid, its in the uk and going to go less than a new one would cost you.
http://www.ebay.co.uk/itm/Spec-Stage-3- ... CA:GB:1123
Emerald standalone, engine builds + e30 repairs - TheEngineShedOnline@gmail.com
