1) I”˜ve been offered an M52B25 for a good price. Is this any use to me for building the M54 gubbins into? I already have an M50 mani, pink injectors etc on the motor currently sat in the E30. Are there any other differences I need to be aware of or is the B25 just as apt for receiving the M54 innards as the B28?
2) Other than the crank & conrod shell bearings, piston rings, oil seals and gaskets, what else is a good idea to replace? Timing chains? Oil pump drive chain? Oil pump rebuild? Timing chain guides?
3) Do I have to use the big ass harmonic damper crank pulley thing off the M54B30?
4) I”˜ve read (thanks f0xy!) that the M52 windage tray needs a little modding to clear the longer stroke crank. Can I use the M54 windage tray and oil pump instead or is that a no-go?
5) I”˜ve kept the lifter block, journal caps and lifters that go with the M54 inlet cam (ordered, of course). Is this a good idea or am I as well just dropping it into the M52 stuff?
I think that”˜s about it for now. Any help is welcome, many thanks
