No fogs front or back
sam2015
Hello all My fog lights don't work front or bk I have no light on the dash telling me they are on dose anyone no what the fault could be and or fuse /relay location to speed things up a bit ? It's an f reg 318 I thanks a‘a
BenHar
Clean the switch.
Ben
Ben
darkchild
Yep, done this on mine last year. Problem solved!BenHar wrote:Clean the switch.
Ben
sam2015
Ok I will give this a go today and come back to you thanks
Before you start pulling bits apart, and risk introducing faults that you didn't have before, TEST!
Pull out the switch and disconnect the plug. Turn on the ignition and lights, and use a short piece of wire to link together the grey wire on pin 7 and the grey/blue wire on pin 5. This should make the front fogs light up.
Now link together the yellow/black on pin 2 and the grey/purple on pin 4, which should make the rear fogs light.
If both these work, then the switch needs taking apart and cleaning.
sam2015
Pulled switch powered fogs with power probe they worked so cleaned switch inside and it's all working thanks very much people
