Crazy N47
hotross
Fri May 22, 2015 10:42 pm
Ok i know they are poo engines but...
Get this one.. car turns over wont start all good fuel pressure and so on..
No fault codes. unplug the cam sensor, Boom it's running.
Now a fault code for the cam sensor no signal code because its not plugged in, but it runs without it plugged in. Plug it in and it will not start with not a single code WTF ???
Used another sensor just to make sure from another car that i know works and still the same result lol
Anyone that can work that one out the drinks are on me!!!
irish320i
Sat Oct 24, 2015 10:46 pm
timing is of ? car sees timing is of wont allow to start would be my guess
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
Sat Oct 24, 2015 11:44 pm
If the timing was out and it measured that from the cam and crank positions you would normally get fault codes stored along the lines of engine speed deviation, plausibility or camshaft to crankshaft sensor deviation. The exact description eludes me.
Does it start if the cam sensor is plugged in and the crank sensor disconnected? On the N47 if the crank speed can not be read then it will work out engine speed from the cam sensor and run but with extended cranking time before it fires.
Has the engine had any other work?
Mon Oct 26, 2015 6:51 am
I would think he's torched it by now if it's not been fixed considering the question was asked back in may. :wink:
Tue Oct 27, 2015 11:00 am
Oops!
A sign of the times on here tbh.
