main beam
elf
Post Sun Oct 18, 2015 6:01 pm
Hi all my full beam appears to have stopped working ..bulbs OK fuses OK .wiring seems OK..could it be the arm on the steering colum any help appreciated thanks .
Post Sun Oct 18, 2015 8:42 pm
Does the full beam flasher work?
elf
Post Mon Oct 19, 2015 7:08 pm
Hi no I've got nothing .neither does full beam light come on dash .I do have main beam lights OK .thanks for reply brian
Post Mon Oct 19, 2015 11:12 pm
I think you mean "I do have dipped beam lights OK" in your last post.
Pull out relay K3, and confirm that both main beams come on when you link together pins 30 and 87 of its socket with a piece of wire. The terminals are marked on the relay.
Note that any online wiring diagrams you find for the headlamp and foglight circuits, are likely to be applicable to the US market, and differ considerably from the UK version.
elf
Post Tue Oct 20, 2015 7:21 pm
Thanks for that Brian I will give it a go and let you know..thanks again.
