Door lock removal
jb1
Sat Oct 17, 2015 9:04 am
One of my locks won't turn so I thought I would remove it and take a look. Also while its out I would get the barrel code for a new key. With the door card removed I found that access to it is really restricted. Will it require the window mechanism to be removed?
alexm3uk
Sat Oct 17, 2015 9:40 am
Did this the other week long screwdriver and push the holding clip towards front of car and should pop out
If you can't get your hand in there to put back then maybe have to take parts out the way a˜„
jb1
Sat Oct 17, 2015 10:14 am
Cheers, figured that might be the case. I was concerned that if it was a struggle to remove that clip then the reverse procedure would be worse.
Sat Oct 17, 2015 10:19 am
Window mech. is very easy to remove and replace (three bolts and a nut). Use a wedge between the weather seal and the glass, or duct tape over the top of the dor and down each side of the glass, to keep the glass in the fully up position.
jb1
Wed Oct 21, 2015 1:47 pm
Thanks, will give it a go at some point. Might try some WD40 in the lock first.
JungleGus
Wed Oct 21, 2015 2:04 pm
It's fiddly, but you do need to take the mech out
Not impossible, just frustrating!
