m50 oil pump refurb ?!
StefanAnghel
Tue Oct 13, 2015 7:20 pm
Anyone knows where I can find any info about how to do it and what parts to replace?
Also how to secure that nut that comes off?
Thanks[/b]
Tue Oct 13, 2015 10:33 pm
You can buy the rotors from BMW, the nut only comes off if the person that tightened it has a limp wrist! A bit of loctite wouldn't hurt though :D
motormanmick
Tue Oct 13, 2015 10:57 pm
Link below, not the cheapest option, but explains everything, nut can be locktited (I think least preferred), drilled and wired or tack it on with a mig.
parts
https://www.realoem.com/bmw/enUS/showpa ... Id=11_6017
link to someone who did a rebuild and said it went well, no pic's
http://www.bimmerfest.com/forums/showth ... p?t=749157
after looking at that, will probably do mine after I get my engine together, let me know how it goes, cheers.
StefanAnghel
Tue Oct 13, 2015 11:34 pm
That doesn't look bad... Thanks for that
I'll probably have a go and take some pictures for further reference
I think we need to update the zone to add pictures easier
StefanAnghel
Thu Oct 15, 2015 8:17 pm
I've opened up the oil pump and the rotors are imaculate,no nasty wear, doesn't shake... Everything moves smooth
The bloody spring nearly poked my eye after I removed the safety pin
Should I leave it like that or ordered them and change it ?
I'll put some pictures up when I log in with a computer
mattxr2
Thu Oct 15, 2015 8:25 pm
I bought a new one from bmw on here for £240
Loctite or weld? I was a bit dubious of putting heat on the shaft
StefanAnghel
Thu Oct 15, 2015 8:28 pm
Mine looks like new
I will loctite it
Don't really fancy wasting money
mattxr2
Thu Oct 15, 2015 8:31 pm
S50 so not much choice
motormanmick
Thu Oct 15, 2015 11:23 pm
Been cutting out some rust in my e30 and stitch welding new sections in some panels, so I'll mig 2 tacks, let her go cold between tacs, it'll be fine and never come off, I love security.
