Removing check panel and associated loom
Bristol_Jer
Post Sat Oct 10, 2015 8:50 pm
I want to remove the check panel and loom from my car as I have no need for it as it is just a stripped out trackday car.
From having a quick look at the wiring, it seems the check panel wiring is all linked in with the main loom that runs down the n/s of the car. Is that the case or is it linked in with the whole car loom and fusebox?
I was thinking it would be a case of sourcing a non-check panel n/s loom and swapping it with mine or is it more involved than that?
Post Sat Oct 10, 2015 9:33 pm
Check panel loom is an integral part of the main body loom and fusebox. Can't be removed.
Bristol_Jer
Post Sat Oct 10, 2015 11:18 pm
Ok, Thank you :thumb:
