M20 2.5 with 6 branch, heat shield?
Sambe30
What can I use as a heat shield on my m20, it has a 6 branch and the ht leads sit above it with no shield[/u]
Ianb
Have you not used an original E 30 exhaust gasket as that has the shield built in and is fine with a 6 branch.
BenHar
You should be able to use the standard manifold gaskets which have a built in heat shield.
Ben
Ben
Sambe30
2 of these then? Or do they come as 2 parts ? http://www.eurocarparts.com/mobile/ecp/ ... 786&000462
Sambe30
Oh sorry should have read it properly
is it just the studs on the manifold I need to remove? No other parts? 10 min job?
reggid
you remove the nuts pull off the manifold, add the gasket then the manifold then do up the nuts
E30 325is with M20B31
