identifying engine
Benzon
Hello, i bought a M20b25 engine.
it has these numbers, on top of the block:
BMW 1278 921 083 86
At the dipstick: A 1 83 320EL
And there is a print with 84 on the left side of the block aswell
My question is, is this just an normal m20b25 engine? if yes, why does it say 320EL?. i do know it is a m20b25, because of the 84, since the 320i is with 80.
Im thinking might it could be Eta or something? i dont know.. someone know?
BMW 1278 921 083 86
gromgsxr
there will be a flat area on the block near the dipstick with some numbers on it that states what engine it is
Benzon
these numbers are gone... so what to do now:P?
bookmark
Measure the bore?
It will be either 80mm or 84mm....
Benzon
it is 84, there is a print of that on the block. but why does it say A 1 83 !!"320EL"!! at the dipstick?
kam-325i
got any pictures ?
Benzon
Im a noob to this forum haha, how to i post pictures?. i got some picture ready
bosers
Isn't the 84 the year of manufacture?
Benzon
nope, ø84 indicates it is a m20b25, the 320i is with ø80
but how do i post picture, so people can see what im talking about
bookmark
Benzon
http://www.bilgalleri.dk/fotoalbum/tuni ... 170079-m20
check this, i posted the pictures there, hope you can identify my engine now
kam-325i
The engine type number and engine serial number have been removed.
The numbers you can see stamped by the bottom of the dipstick ARE NOT OEM.
The engine type number should be within the red circled area, with the engine serial number just below the red circled area. The engine type number should be 256 E/K 1 for a M20B25
kam-325i
Its got the B25 head (early one) and inlet manifold.
Benzon
so how do i check if it is a 2,7 or 2,5 block?. the bore is 84 as you can see on the pictures.
im thinking im going to visit BMW tomorrow, to see if they can try to find something that we/i cant ;(
kam-325i
There is nothing else on the block that will help you, and BMW will tell you that aswell...
Only way to confirm is to measure the Stroke and Bore....
Benzon
Alright, thanks alot for your help;-)
bimanut
I wouldn't advise walking into a dealers asking about an engine that's had its serial numbers removed!!
reggid
look at the piston crown shape through the spark plug hole, it might help narrow it down
E30 325is with M20B31
