Engine make-up
Orangecab
Post Tue Sep 22, 2015 8:50 pm
I am wanting to make the engine look a bit smarter, ie black inlet manifold and black rocker with polished raised bits, possibly shines bolts etc,
Any ideas/what people use to achieve this look, is it a case of just spraying the bits as at the moment the bay is looking very aged!
Thanks rob
ross_jsy
Post Tue Sep 22, 2015 9:06 pm
Pretty much. Degrease the parts thoroughly, key with some sandpaper, etch prime then top coat. Then sand the raised sections
Orangecab
Post Tue Sep 22, 2015 9:09 pm
Would I have to use any particular paint? Or just normal car paint? I only ask as obviously heat from exhaust manifold might bubble the paint on the rocker cover?
ross_jsy
Post Tue Sep 22, 2015 9:11 pm
When I have done it in the past I have just used regular spray paint and it's held up fine.
Orangecab
Post Tue Sep 22, 2015 9:14 pm
Ok cool, I'll give it a shot! Cheers
rotta
Post Tue Sep 22, 2015 9:37 pm
i used a crackle/wrinkle finish on mine avaliable from halfrauds or online
pierce
Post Wed Sep 23, 2015 5:10 pm
I guess it depends how far you want to go.....
I really would recommend getting the parts vapour blasted first. You may even decide they look fine in their "as new" state.
Crackle black paint is the one!!!!!
you can painstakingly scrape / file down the "fins" and logos or take them to an engineering shop and get them "surface ground" looks very very smart indeed.
ross_jsy
Post Wed Sep 23, 2015 5:56 pm
Block of wood with sandpaper round it is an easy way to sand the fins down. Doesn't take very long
jimbom30cab
Tech 1 freak
Post Wed Sep 23, 2015 6:16 pm
or you could buy this from me
£30
location Hants/West Sussex
Orangecab
Post Wed Sep 23, 2015 6:22 pm
Where in West Sussex? Don't suppose you'll be at Santa pod?!
jimbom30cab
Tech 1 freak
Post Wed Sep 23, 2015 6:39 pm
Nope but I work in Chichester once a week (Tangmere)
Orangecab
Post Wed Sep 23, 2015 7:04 pm
Ok, would you post? I could make it to chi but I wouldn't be sure when!
jimbom30cab
Tech 1 freak
Post Wed Sep 23, 2015 8:00 pm
yes of course, drop me a PM
