E30 M3 V10
P_VIDDY
Post Mon Aug 31, 2015 5:40 pm
Had a look at this at Gaydon. It is simply epic! Looking forward to seeing it again at Santa pod. As above hope you do some runs in it :D
KW355
Post Sun Sep 13, 2015 6:21 pm
I have brought an evo 2 spoiler off a zoner (thanks Jim ) and painted it myself. I have had a bit of a struggle getting the colour right and ran out of paint tinter and painting skills after 3 repaints, I am going to leave it on for now and get it professionally painted over the winter.
I have also rewrapped the under bonnet wiring and removed the redundant s14 wiring.
The M5 oil cooler was looking a bit vulnerable, I have fitted some mesh inside the vent. it looks like the are clips to fit something here, I cant see anything on realoem, does anybody know if there is a proper mesh for the lower vent ?
A few pics, excuse the thumb on the frontal shot, my photography skills match my painting skills :D
Post Sun Sep 13, 2015 7:02 pm
No mesh on the front bumper vent but there is meant to guide which fits the full width of the bottom vent.
glenn
Engine Transplant Services
Post Sun Sep 13, 2015 7:14 pm
I've just been out to the garage keith, and found the guide as barry has said. I removed it as it wouldn't fit with the e60 oil cooler. there's no mesh on it, it looks similar to a 325i oil cooler grill. I can pop it in the post to you this week if you like keith ?
KW355
Post Sun Sep 13, 2015 8:32 pm
glenn wrote:I've just been out to the garage keith, and found the guide as barry has said. I removed it as it wouldn't fit with the e60 oil cooler. there's no mesh on it, it looks similar to a 325i oil cooler grill. I can pop it in the post to you this week if you like keith ?
Thanks for the offer Glenn, I have fitted the mesh now so I won't need it.
I just wondered what should be there as there are fixings for something. :D
bmw-mad
Post Sun Sep 13, 2015 9:33 pm
Looks much better with the EVO 2 lip
This Car just seems to be getting better and better :D
KW355
Post Mon Sep 14, 2015 7:48 pm
bmw-mad wrote:Looks much better with the EVO 2 lip
Thanks, are you all going to Santa Pod ?
bmw-mad
Post Mon Sep 14, 2015 8:08 pm
Yes we will be going :D
Post Mon Sep 14, 2015 8:55 pm
Keith, don't wait for them, they'll be late as usual. :D
M-Sport
Post Mon Sep 14, 2015 9:20 pm
Fook off Rav we was only an hour or so late :mad:
M-Sport
Post Mon Sep 14, 2015 9:21 pm
Keith I have a genuine Evo 3 splitter if interested :)
Post Mon Sep 14, 2015 9:28 pm
What shade red is that? Looks lovely :cool:
M-Sport
Post Mon Sep 14, 2015 9:39 pm
Looks Imola red ?
Post Mon Sep 14, 2015 9:48 pm
That's what I initially thought as it's darker than Henna Red.
KW355
Post Tue Sep 15, 2015 7:27 pm
ImysE30 wrote:What shade red is that? Looks lovely :cool:
Which bit ! the car is imola red 2, the evo 2 spoiler is almost imola red 2
KW355
Post Tue Sep 15, 2015 7:32 pm
M-Sport wrote:Keith I have a genuine Evo 3 splitter if interested :)
Thanks but I have had enough of spoilers for a bit :mad:
How much is it though ?
KW355
Post Sat Sep 26, 2015 4:13 pm
I have been doing a few bits and pieces to the car, first I ordered this from Americaland ;
It is an external temperature sensor for the 13 button obc I have fitted, it cost £20 delivered with a 10 year guarantee. I thought about where to fit it and eventually put it in the grill next to the headlight.
It seems to work fine, I initially thought it might read incorrectly with the air blasting past it.
I have brought a pair of inlet plenums as the ones on it were a bit singed but worked fine. (the original engine come out of a fire damaged car )
Note the temporary fuel filter by the brake fluid reservoirs which I fitted after the blocked injector problem. I believe the crap in the injector came from internal rust on the steel front to back fuel line. I have brought a new fuel line (£42 from BMW ) and plan to fit it over the winter.
The front badge was looking a bit worse for wear;
I rubbed the aluminium m and 3 down with wet or dry and metal polished them, I brought some vinyl strips in the m colours and cut them to size and lacquered them.
I noticed that the light grills have lots of blanks between the slats, presumably to keep the rain out. I set about it with a dremel as the air boxes are directly behind the headlights. I hope to reduce the intake air temperature by doing this.
You can just see the external temp sensor next to the headlight In between the bottom 2 slats.
I have machine polished the car ready for Santa Pod tomorrow, Just a few shots of it in the garage;
jimbom30cab
Tech 1 freak
Post Sat Sep 26, 2015 4:16 pm
Awesome update
Would you have a link to the temp sensor please, I need a couple
KW355
Post Sat Sep 26, 2015 4:45 pm
jimbom30cab wrote:Awesome update
Here you go;
http://www.ebay.co.uk/itm/251269450085? ... EBIDX%3AIT
It took about a week to arrive from ordering, there was no additional fees from customs.
glenn
Post Sat Sep 26, 2015 5:09 pm
really looking good keith 8)
KW355
Post Sat Sep 26, 2015 5:15 pm
glenn wrote:really looking good keith 8)
Thanks Glenn, I spent over a day polishing it !
jimbom30cab
Tech 1 freak
Post Sat Sep 26, 2015 10:49 pm
Thanks Keith
bigbird76
Post Sun Sep 27, 2015 8:44 pm
Nice to meet you today Keith, was parked next to you
Leigh
KW355
Post Mon Sep 28, 2015 8:22 pm
bigbird76 wrote:Nice to meet you today Keith, was parked next to you
Leigh
Likewise Leigh, It was a good day :D
bigbird76
Post Thu Oct 01, 2015 4:38 pm
Sorry to jump thread but I am curious to know if a E46 air temperature sensor would fit a E30?, Obviously the wiring connector is different but is it possible?
Not sure about internal readings etc?
Leigh
KW355
Post Thu Oct 01, 2015 6:40 pm
bigbird76 wrote:Sorry to jump thread but I am curious to know if a E46 air temperature sensor would fit a E30?, Obviously the wiring connector is different but is it possible?
Leigh
I am not sure but they have different part numbers, the e46 ones seem cheaper on ebay so it would not be expensive to find out. The e46 ones seem to be about a tenner, personally I would buy the one I did as it works first time and has a 10 year guarantee for £20
S38B38
Post Sat Oct 03, 2015 12:59 am
8) ,, fantastic car
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
bigbird76
Post Sat Oct 17, 2015 5:56 pm
Leigh
In the end I ordered the one from the USA, It arrived in the week and I Installed it yesterday and my 6 button OBC now has the correct temperature. Also while I was there I changed my obc to Celsius from Fahrenheit by switching the small screw fitting on the rear of the obc unit.
Leigh
KW355
Post Tue Dec 22, 2015 3:23 pm
I haven't done much to the car lately apart from changing the steering rack gaiters.
I have been collecting parts for when I strip out and refurb the rear beam over the winter, I plan on powdercoating / painting the rear beam and arms, powerflex bushes and black diamond hoses with new brake and fuel lines.
I have fitted a set of gauges from an Audi, I chose these because they have the same font as the e30, light up orange and have red needles like the M3.
When I got them the bezels were a bit scabby;
(photo aspect gone a bit egg shaped ! )
First I polished the plastic 'glass' with rubbing compound to remove scratches and then I stripped off the paint with a scuff pad (came off easy as the paint was thin) followed by satin black paint.
I picked the Audi loom apart, removed the relay and separated the lamp earths so I could connect them via the e30 dimmer system.
I chose to fit them in the stereo position as I haven't got a stereo because the car is too loud to hear one !
The fascia plate I used was an old genuine BMW one which I found in my garage, probably out of one of my old e30's from a few decades ago.
I discovered the gauge write up in the wiki after I had finished, one discrepancy I found was the vdo pressure gauge sender, it quotes the American part number (360-007 ) not the u.k. one which is; 360-081-030-006c. the spec for the v10 is m12 x 1.5 thread 0-5 bar, 10 to 180 ohms, two post sender with warning contact.
The temperature sender was correct in the wiki, I brought a Meyle one for £6 part no. MEY1008100004
My car used a positive to feed the low oil pressure warning light, because I used sender with a built in negative switch for low oil pressure I had to convert my dash oil warning light to suit.
As my vent gauge already reads engine oil temp I plan to install a sender in the rear diff. I have the M3 tachometer oil temp gauge connected to my gearbox, this normally runs at about 50 degrees c.
As the oil temp gauge does not start till 60 degrees c I may fit a sensor which over reads so I can establish a 'normal' but false reading for the diff temp.
Post Tue Dec 22, 2015 5:39 pm
Good work
KW355
Post Tue Dec 22, 2015 7:14 pm
Rav335uk wrote:Good work
Thanks Rav :D
steve_k
Post Tue Dec 22, 2015 8:17 pm
been reading this from the start, really impressed with the car,
also, thanks for the part number for the oil temp sensor, been trying to find one that don't cost the earth :D
KW355
Post Sun Dec 27, 2015 3:06 pm
steve_k wrote:been reading this from the start, really impressed with the car,
For cross reference purposes the genuine Audi part number for the oil temp sensor is;
AUDI 049 919 563 B (049919563B)
I think it is about £20 from an Audi dealer.
The one I brought;
http://www.ebay.co.uk/itm/191313234782? ... EBIDX%3AIT
I tested the Meyle one by connecting it to the gauge and dropping the sensor end in boiling water, it read exactly 100 degrees c
VDO's agent in the u.k. are based in Birmingham, they have a technical helpline on 0121 326 1271.
steve_k
Post Sun Dec 27, 2015 3:12 pm
The one I brought;
cheers dude :D thats the one i got, took the part number to a local motorfactor & got it for under a tenner :D
damn site better than £40++ for a VDO one.
Post Sun Dec 27, 2015 3:31 pm
I was going to try this one as it has a proper 2 pin connector and is 0-170 which is what the gauge shows http://www.ebay.co.uk/itm/180847879900? ... EBIDX%3AIT
