M40 + Walbro 255 = fuel starve?
Acaciastrain360
As the title says.... I had an M50 now gone back to M40, but I still have the 255 pump fitted. It runs fine on start up for about 30 seconds and then splutters and dies... Too much fuel pressure? or not enough fuel? Or something otherwise like dirty filter? (Fitted new one 3 years ago, and has been sat the past year in garage..)
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
Acaciastrain360
So it's more likely to be the filter or a dodgy regulator?rix313 wrote:The fuel pressure is regulated by the regulator on rail not the pump.
- **BANNED**
If the engine fires immediately then the rail is retaining fuel pressure,so you have a supply problem.
Youth is wasted on the young.
Acaciastrain360
Yeah it starts and runs fine then eventually conks out, so I'll check filters etc cheers
Acaciastrain360
So I've put the standard fuel pump in and checked that all filters are clean and it STILL starts lovely and then dies after 30sec-1min! It's getting boring now :/ any more idea So?
- Brianmoooore
If the pump and filter were fine with the M50, then they'll be OK with the M40, unless something has changed in the meantime. A blocked filter will be immediately obvious if you power the pump briefly with the fuel feed pipe disconnected from the fuel rail.
What colour are the spark plug tips after it stops? From this statement it looks like a (blue) coolant temp. sensor problem.
Acaciastrain360
Defiantly not blocked, I've already soaked the garage floor haha... With regards to the coolant temp. Sensor.... Would this have such a major effect on the running of the engine?Brianmoooore wrote:If the pump and filter were fine with the M50, then they'll be OK with the M40, unless something has changed in the meantime. A blocked filter will be immediately obvious if you power the pump briefly with the fuel feed pipe disconnected from the fuel rail.
Acaciastrain360
I've put a spanking new blue sensor on... Still runs like crap! I cleaned the plugs and put them in and they come out black and sootie!!!! I need help haha this engine sucks!Acaciastrain360 wrote:Defiantly not blocked, I've already soaked the garage floor haha... With regards to the coolant temp. Sensor.... Would this have such a major effect on the running of the engine?Brianmoooore wrote:If the pump and filter were fine with the M50, then they'll be OK with the M40, unless something has changed in the meantime. A blocked filter will be immediately obvious if you power the pump briefly with the fuel feed pipe disconnected from the fuel rail.
Acaciastrain360
Thanks, yeah I've read other people posts and realised its not the right way about it... I will be getting it plugged in this week too which might help source a fault.
