Federal RSR tyres splitting/delaminating
Hi guys,
I run an E30 track car, weighing 1100kg.
It has the standard 15inch BBS wheels, fitted with 195/50/15 Federal RSR tyres. I’ve had them on for about 8 months/2000 miles and a crack has appeared in each tyre, running from inner to outer side wall.
I contacted the (reputable) company that I bought the tyres from and I’m being told that, I need to remove them immediately.
Apparently the reason they have cracked is because the tyre is incorrect for my car in terms of size and load rating.
Also they reckon I've not taken them through a proper heat cycle.
I think this is b****cks, but I’m happy to be proved wrong. Anyone had this happen to them?
What track tyres do you run?
Cheers, Rob.
Cheers, Rob.
I've not heard of a road tyre needing a heat cycle either.
I don't really mind that they have a crack in them, I just wanted assurance from my tyre supplier that there'd be no issues but they've just basically told me that they've spit because the tyre's not designed for my car and I've not heat cycled them.
The tyre's do have a warranty but the suggestion is that I've voided it based on the above.
Do most of you guys run medium compound R888?
Just tell me to shut up and point me in the direction of a tyre thread if you like!
I used the rsr, no cracks but the inner edge has delamed. I had them
Turned around due to camber wear but never noticed it. After a track day I noticed it on the outside.
I'm using Nankang ns2r in soft. Used at 2 events one being silverstone at trax and I rate them over the rsr, I changed due to the delam and they are poor in the wet
I usually do a burnout on the rears to put a cycle through them to limit tyre delam, they may want you to scrub them with a couple of hard laps and let them cool down
I'm no expert tho
I'm no expert tho
I had Nankangs on an E46 325i a couple of years ago and they were really good, but that was a 255 section on the rear so had loads of grip. My track car has more power than the E46 and is only a 195 section, so I want something pretty sticky.
I am really tempted to try the ns2r based on price.
Demlotcrew
RSR's are complete rubbish throw them in the bin.
They're on their way! What do you have?
Demlotcrew
I run Khumos, Dunlop and Michelin. I really rate Khumo V70's though, probably best R tyre on the market right now.
Cheers mate, I'll look at getting a set of those.
After a quick search it looks like Demon Tweeks is the cheapest place to buy them.
Is medium compound the way to go on these?
Bearing in mind I'd like to get a good few track days and maybe a couple of thousand road miles out of them.
Demlotcrew
Go for the hard, the only downside is that they need quite a few laps to get working, but once going they are fantastic.
That's good, it usually takes me a few laps to get going too!
Thanks mate.
Thanks mate.
Demlotcrew
They offer marginal grip over a road tyre, just all show and no go sadly.
- Mikey_Boy
Interesting you say that as I've heard views both good and bad from Subaru and Mazda MX5 racers. Having been out in a racing Mazda with them fitted, I thought their performance was pretty close to an R888, certainly in the dry.
I've bought a set for my new build (as 215/40R17 sizes are limited to that and Yokohamas) so will be interested to see how they measure up, good or bad...
Demlotcrew
You need to get some data logging on the car, its the only way to know for sure whats going on. Otherwise its just guesswork.
I did think they were pretty good on track and others commented on how well my car turns in at speed but my experience is limited.
My test will be to go to Curborough sprint circuit. I know how exactly how quickly I can get round there on the Federals, in theory the Khumo V70 will make me quicker (hopefully).
Demlotcrew
Hmmm, the hard compound is really not that well suited for sprint circuits. High performance tyres need to be 'bed in' on every track, it takes time and you must get them up to temperature (optimal 70ºC), I don't think you will be able to do that?
Of course if you have tyre heaters then you will be ok.
No tyre heater's I'm afraid.
I'll perhaps go for the medium compound as I do just as many sprints as I do track days.
Demlotcrew
Yes I would say you must go for a softer compound.
These are mines after a good session.
- Mikey_Boy
Having worked trackside in F1, you have some merit in stating that - however, for a track day (or race) car where subjective feel is a major (and sometimes overarching) factor in terms of driver confidence, what you say is frankly a load of bollocks. Road tyres are developed using subjective feel as a major sign off parameter as well.Demlotcrew wrote:You need to get some data logging on the car, its the only way to know for sure whats going on. Otherwise its just guesswork.
You'll be working for McLaren before you know it, bestowing the virtues of marginal gains...!
I'll continue pursuing the fun for now, not the numbers...
Demlotcrew
In so many cases 'engineers/managers' use data to accelerate change where drivers use too much feeling and get no where.
Demlotcrew
Well you have your way of building a car, I have mines.
If I told you that a driver I worked with was convinced that RSR's were the best. We ran his E46 M3 fitted with new RSR's round the ring. Then fitted some new Khumo KU39's and despite a lot more tyre squeal the car was on average 7s faster!!!! Would you be able to 'feel' 7 seconds?
7 seconds faster round the ring?
- Mikey_Boy
Andrew - I hear you. My point is that for us lot messing around with cars, just chasing the numbers is of limited value - data is always king for sure, I'm not disputing that. However, confidence to push on is a mighty factor as well.
I think my new car will 'feel' awesome! I really don't care if it's not the quickest - If I was chasing numbers, I'd be building something very different - each to their own!!
Demlotcrew
The KU39 is classed as a mid range road tyre.......Rob175kks wrote:7 seconds faster round the ring?
29 wet, 25 dry. Same all round. But I don't really know what I'm doin. I'll be interested to hear from others.
I've not seen/used this site before, but check out the price on these!
http://www.oponeo.co.uk/tyre-details/to ... g#95781760
- Mikey_Boy
It's a great site - I got my last set of Contis and Michelins from there for other cars... I think I got the Federals for my current track build from there too.
Great service too!
Great service too!
