Any Cab roof experts out there?
tom325sport
Post Sun Jul 19, 2015 1:43 pm
So I want to sort my electric roof. At the moment it is half manual (roof) and half electric (horseshoe). I think I'm right in saying that I will need the re-enforcement plate that will go over the top of this to fix it...?
Also can someone please tell me if this looks right?
The top red arrow shows a bolt that looks like it should attach itself to the arm to the right of it - What should go here? I can't seem to find the right part number. Number 9 maybe?
The bottom arrow - should this be straight?
Also the other side (passenger side) looks similar to the one above. it looks like it's missing something?
Thanks in advance.
manse73
Post Sun Jul 19, 2015 2:15 pm
That bit you are pointing at in the second picture I couldn't get when I had my Motorsport. I ended up going to Bmw for the dimensions and getting a local engineer shop to make me two as I needed the other side as well
bruv chariots rule
j4gz
Post Mon Jul 20, 2015 12:56 am
tom325sport wrote:So I want to sort my electric roof. At the moment it is half manual (roof) and half electric (horseshoe). I think I'm right in saying that I will need the re-enforcement plate that will go over the top of this to fix it...?
Thanks in advance.
The parts you will need in order to get you roof going will be 16,20,3,10,14,11
tom325sport
Post Mon Jul 20, 2015 7:28 am
Hi thanks. Yes I have all them. They are removed so I can manually open the roof.
Gert_8
Post Mon Jul 20, 2015 9:32 pm
You are missing the closing rod. Part numbers: 3,10,11 & 14
You will also need to repair plate you have mentioned, but I am
Assuming you still have both the upper and lower levers that the rods, 3 & 2 attach to
tom325sport
Post Mon Jul 20, 2015 10:08 pm
Hi thanks for this. As mentioned I have all the necessary parts. These have been remove so I can close the hood manually. OK so I need the repair plate but what about the arrows on the picture? Which part numbers are these?
Thanks.
Gert_8
Post Tue Jul 21, 2015 11:04 am
In your first pick with the two arrows - nothing is missing on the lower arrow, this is just a moving part. The arrow above it looks like it is is missing a circular pin (part 13). just keeps the lever moving within the slot. Possibly on both sides...
tom325sport
Post Tue Jul 21, 2015 9:18 pm
Gert_8 - thanks so much! I might try and straighten the bottom bit where the bottom arrow points to as on closer inspection it looks bent.
I'll get them pins (part 13) ordered too, as well as the repair plate. I'll let you know if it works. Thanks again. :thumb:
Gert_8
Post Tue Jul 21, 2015 9:31 pm
Pleasure. Please do let us know.
tom325sport
Post Tue Jul 21, 2015 10:27 pm
Actually Gert_8, after doing more research it looks like a bolt and not a rivet. Could it be part number 8?
This chap had the same problem....
http://www.r3vlimited.com/board/showthr ... 80&page=14
tom325sport
Post Tue Jul 21, 2015 10:40 pm
Or one of 28!!!!!
http://www.realoem.com/bmw/enUS/showpar ... Id=54_0146
There's loads!! Help.
Gert_8
Post Wed Jul 22, 2015 9:37 am
I'm referring to this pic..
The top arrow is where I think part #13 fits. It serves as a guide that fits into the slot on the right hand lever (which by the way, looks like it may be bent).
It might be an idea to take that pic to your BM Dealer and ask their parts department for an opinion, but looking at the exploded diagram, part 13 looks like the one you're after on that side.
The other image, I'm guessing, has a similar arrangement (I haven't really paid much attention to this side, because when the roof breaks, the forces involved usually affect the right hand linkages.)
Gert_8
Post Wed Jul 22, 2015 9:47 am
I have had a look at the thread you posted above, and it does look like a screw, but the exploded diagram, part #13 looks to me to be the right size than part #8. It may be the drawing doesn't show the slot?
tom325sport
Post Wed Jul 22, 2015 11:13 am
Thanks for your advise. I've had a look at part number 13 (54318129346) on google and should it look like this...
http://www.ecstuning.com/BMW-E30-325i-M ... /ES158307/
Gert_8
Post Wed Jul 22, 2015 11:28 am
That looks right - it slots into the groove on the lever to the right of the first arrow.
What is confusing me, is the lever itself has a pin protruding, so how does is attach? :?
tom325sport
Post Wed Jul 22, 2015 2:01 pm
Ok yes that makes sense. The pin that's producing out is maybe because it has snapped off and that's what's left?
tom325sport
Post Wed Jul 22, 2015 9:40 pm
So Gert_8 - typed part number 8 (54318134533) into goggle and this is what I found? It looks more like it do you think?
http://www.ecstuning.com/BMW-E30-325i-M ... /ES158308/
Gert_8
Post Wed Jul 22, 2015 9:51 pm
If you can tell me whether you can remove the "pin" that protrudes on the lever, highlighted with your 1st arrow and this part screws in to replace it, then it's the one. Take a look at that pin thing please.
tom325sport
Post Wed Jul 22, 2015 10:00 pm
Thank you - yes I will take a look soon and report back. Thanks again for your help!
Gert_8
Post Wed Jul 22, 2015 10:08 pm
I'm surprised not to hear from Benhar and Willnz.
BenHar
Post Wed Jul 22, 2015 10:27 pm
Gert_8 wrote:I'm surprised not to hear from Benhar and Willnz.
I've never actually seen an electric roof mechanism.
Just interested.
Ben
Gert_8
Post Wed Jul 22, 2015 10:36 pm
I was hoping one of you guys would confirm we're after part #13! :)
BenHar
Post Wed Jul 22, 2015 10:38 pm
Gert,
Can you take equivalent pictures of yours to show what it should look like?
Ben
Gert_8
Post Wed Jul 22, 2015 10:39 pm
I was planning to do just that, but at the weekend.
BenHar
Post Wed Jul 22, 2015 10:54 pm
There are some more pictures of the meachanism in this thread: http://www.e30zone.net/modules.php?name ... f&start=50
Might help?
The bent piece that your lower arrow points to looks straight in them.
Ben
tom325sport
Post Thu Jul 23, 2015 7:19 am
That would be great. Thanks so much again :)
BenHar
Post Thu Jul 23, 2015 2:04 pm
Found this in the wiki which has some diagrams: http://www.e30zone.net/e30zonewiki/imag ... ft_top.pdf
Ben
tom325sport
Post Fri Jul 24, 2015 8:49 pm
Chaps thanks so much! That makes sense. In that thread I put up of that chap who had the same problem, someone had sent him a bag of the guide screws, there's a pictures of them a few pages on. So I'm assuming these can be replaced/fabricated somehow. I've had a quick look at mine and I cannot get that broken screw out! Any tips on getting this out? I've been fighting it for a while.
tom325sport
Post Fri Jul 24, 2015 9:34 pm
Willnz thanks so much!!! Could I ask what you mean by peened? Thanks
