M1.3 WIRE LOOM
Post Thu Jul 16, 2015 1:06 pm
i'm converting my old M1.0 to M1.3. i found out my old wire loom near the ecu got 2 connector and is totally different to the M1.3 wire loom connector.
this is my old loom
this is my old loom and this loom will go to the back of my car maybe is to the autobox controll unit.
this is my new loom
(from other post)
Also, my old TPS connector is a round type and the new M1.3 wire loom i bought got a rectangle connector. just swap the connector or i need to buy a TPS with a rectangle plug. the wiki converting to M1.3 did not say anything on this problem and i got no crew on this. please HELP!!!
(from yet another post)
is M40 316i 318i TPS sensor can fit my 325i auto? or mannual TPS same with auto box TPS?
(3 posts combined, 2 surplus ones removed)
Post Fri Jul 17, 2015 12:39 am
sorry for that and thanks for the combined issue. :o: my is a auto box and i just simply want to upgrade my M1.0 to M1.3 only. nothing more on setup. on picture 3 is what connector ? so, how i convert my new loom TPS connector to my old TPS ? PLEASE advise me.
Post Fri Jul 17, 2015 10:23 am
I found out the electronic auto wiring loom did connected to the old 1.0 ecu. that mean i can't upgrade mine to 1.3? or i can do something on that auto wiring loom. And did i need to replace a manual TPS instead using the old round TPS?
Post Mon Jul 20, 2015 9:00 am
hi all, is the M1.3 auto gearbox ecu and wire loom fit my car?
