Heater Matrix plumbing
Bakea012
Post Tue Jul 07, 2015 3:28 pm
Afternoon all,
slowley getting there with the M52 swap, just somthing that has thrown me slightly.
2 hoses going through fire wall for e30 to heater matrix and there seems to be 3 hoses in the e36 can someone please tell me if im being thick or how to get round this?
thanks :mad:
maggspower
Turbo Farmer Tractor Driver
Post Tue Jul 07, 2015 9:36 pm
If you can tell me the correct name for the "fire wall" I'll help you out, maybe :D :D :D
bosers
Post Tue Jul 07, 2015 10:13 pm
Ooh, is it bulkhead, bach? :D
maggspower
Post Tue Jul 07, 2015 10:24 pm
bosers wrote:Ooh, is it bulkhead, bach? :D
It is :D
Before we know it, it will be all hoods, headers, stick shifts, fenders, we'll be having cheese with everything and shagging our cousins :D
*Answer. Remove the heater controler solonoid, the box that was attached to the e36, which will leave you with 2 pipes.
The one from the back of the head goes to the bottom pipe on the heater matrix which comes through the bulkhead.
Hope that helps.
Bakea012
Post Wed Jul 08, 2015 12:47 am
apologies thank you for both of your very unsarcastic comments, bulkhead it is from now on. Relatively new to this. Sorry where is the heater control solenoid what side of the "bulkhead" is it? However thank you was unsure which one went top or bottom.
maggspower
Post Wed Jul 08, 2015 1:14 am
http://www.realoem.com/bmw/enUS/showpar ... Id=64_0126
Part *1 on the above diagram. It will be attached to the heater hoses.
Bakea012
Post Wed Jul 08, 2015 7:16 am
Thanks sorry to keep asking questions do I need to delete one of the hoses or do I need to put the solenoid on the e30? Thanks
bosers
Post Wed Jul 08, 2015 7:32 am
You don't need the heater solenoid on your e30, bin it.
Bakea012
Post Wed Jul 08, 2015 7:41 am
Sweet! thank you which hose to i get rid of? or is not needed?
Thanks for the help its funny how silly things like this can throw you
maggspower
Post Wed Jul 08, 2015 7:56 am
There are only 2 pipes coming off the engine. These are the ones you need, the 3rd that you dont need goes from the e36 heater valve to the heater matrix. It will be obvious when you see it.
Bakea012
Post Wed Jul 08, 2015 8:32 am
Ok Thanks
