shes an 86 325i with 72,000 few oil leaks up front and a tendency to overheat!!
after having her for two months im gonna start on the rear suspension so new meyle subframe and trailing arm bushings poly dif bush 22mm poly bushed sway bar, also got new guibo and e46 steering rack to go in and 15 inch bbs rz with toyo proxes ready to go on gonna be a busy few weeks
