So I've managed to get myself a rare OEM phone with all accessories! However, I am unsure where to mount things ( I know some of you will say wherever I want, but I want it as close to stock as it can be)
My gut tells me that the speaker unit goes in the passenger footwell ( I'm assuming near the original kick panel speaker?). The microphone can run up one of the pillars ( again assume the one closest to the driver- in my case RH side.) the centre console is obvious so no need to ask for that!
These all go into a receiver of some sort that has an aerial (about 10 inch) which clicks into a mount. The million dollar question is, where do I mount this? There is enough cable to reach anywhere in the car ( so I would assume it's meant for the boot?
Once I know this I can look for power supplies nearby. ( I have 1x brown, 1x red, 1x yellow/ black stripe and 1x green) can anyone help clarify which is which. I'm expecting a 12v positive and a negative and maybe a remote to power on/ off when ignition off.
Any help would be great and any pictures/guide would be amazing!
Martin
