M52 Clutch upgrade
JungleGus
Post Wed Jul 01, 2015 3:02 pm
So - I'm not sure if it's my clutch age, or the fact I'm running 240hp-ish through the M20 clutch, but it looks like I need a new clutch.
I am 99% sure I am using the M20 clutch on the M20 flywheel - does anyone have any good upgrade options? +70hp over the stock M20 would make sense to be slipping, and it only seems to slip on hard launches.
Any input appreciated!
Cheers,
Gus
HairyScreech
Post Wed Jul 01, 2015 5:06 pm
A lot of people rave about the sachs upgrade clutch. Think it is just a stock friction plate and uprated pressure plate springs.
JungleGus
Post Wed Oct 21, 2015 2:31 pm
Cheers thanks! Will check it out
motormanmick
Post Wed Oct 21, 2015 10:20 pm
depends on your budget, you could go this way, the guys on the zone also told me must use m52 2.8 starter motor, cheers
http://www.ebay.com.au/itm/FX-STAGE-2-C ... 258c2f040c
Post Wed Oct 21, 2015 10:55 pm
Gripforce offerings are very good for the money, but I would stick with M20 kit, I've got a standard Sachs M20 clutch on my 3.0 with a Gripforce paddle plate, works 100% perfect
