WOULD THIS FIT AN E30 325i?
eun
Post Sun Jan 29, 2006 11:41 pm
Dan318-is
Post Sun Jan 29, 2006 11:48 pm
im pretty sure it would mate?
ask someone else for confirmation but im sure you could make it fit if not surely, its only an airbox
Post Sun Jan 29, 2006 11:54 pm
Probably could be made fit, but if you think it will give you the slightest increase in performance, over the standard airbox and filter then you are living in cloud cuckoo land.
Eddy
Post Mon Jan 30, 2006 12:38 am
Brianmoooore wrote:Probably could be made fit, but if you think it will give you the slightest increase in performance, over the standard airbox and filter then you are living in cloud cuckoo land.
True. :cool:
The standars airbox unit is the far best item for usage in E30 cars...
Building my ultimate drift E30....
M5pilot
Post Mon Jan 30, 2006 7:31 am
The standard air box is not the best thing to have.
That CDA will fit the 325i but only if you buy the corret adapter and some samco hosing. Costs 20 quid through E30zone shop - you'll need to PM me.
There is a small performance gain with this but it only really starts working when you have other mods aswell. Even still, its more about the bling!
Post Mon Jan 30, 2006 9:01 am
Eddy wrote: The standars airbox unit is the far best item for usage in E30 cars...
Wouldn't say that the standard item "is the far best item...", just that, in the real world, and on a standard or lightly modded engine, it will perform every bit as good as any aftermarket item, provided it is changed regularly and not overlooked at service intervals.
You'd be far better advised spending your money on proper basic servicing and maintenance.
