Fuel tank problems
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jun 26, 2015 8:40 pm
Just ran out of fuel 3km short of the German border... fortunately on the slip lane into the petrol station, so it was only a 100m push!
Fuel gauge still showed 20 litres left, and I could only get 40 litres into the tank no matter how slowly I pumped, and the gauge now reads full.
There's no dent in the tank and it's definitely a 63litre job since I fitted it myself. So i'm guessing there's a problem with the internal siphon system. Can anyone shed any light on this?
I was getting 32mpg, believe it or not!
KW355
Post Mon Jun 29, 2015 9:45 pm
It sounds like you have got a mismatched 55 litre / 63 litre fuel gauge / fuel gauge sender unit, especially as you have just changed the tank. did you transfer the original senders to your new tank ?
Grrrmachine
Post Fri Jul 03, 2015 9:45 am
Nope, it's definitely the right tank and gauge. The gaugle says 60l, and since I fitted the tank myself I know it's the larger unit.
I'm thinking that one of the syphon pipes is blocked or crimped somehow, so there's 20l trapped on one side that I cant pump out.
