Car is a 1992 M40B18 Auto, converted for me from an M20B20 (the M40 suits the auto far better than the M20). Owner is an enthusiastic amateur mechanic, whose ambition knows no limits.
I want this finished before we use the car for a trip to France in mid August. I chose the LPG shop for the parts, mainly because they are near to home. On email before my visit, they confirmed they had a single point system available http://www.lpgshop.co.uk/aeb175-leonard ... ambda-ecu/ , as Brian recommends, but asked why I wanted a single point, when the car was running multi point petrol? I deferred to their knowledge and came away with an LPG Tech Tech One system, which their software lists for the M40.
I came home with this lot, plus a toroidal tank. The multivalve (tank outlet) and filling kit were out of stock and are arriving in the post. I intended to fit a lambda sensor, but Greg tells me it’s not necessary, this kit uses the signals to the original injectors to decide the gas output.
Very pleased with the quality of the parts, even if I do need to figure out what goes where myself. There are six different types of hose included, but it’s obvious what each is for. Instructions are basic, but only leave a couple of questions to be answered.
First job is to decide where the main components will be fitted. Initial thoughts are ECU in the car, near the original. Injectors, filter and sensor on the panel at the back of the engine bay that covers the heater. That leaves the reducer, which needs two water pipes, a high and low pressure gas connection and two sets of electrical connections. It’s not small.
It’s either under the servo, near the AFM on the redundant M20 relay mount, or behind the headlights. First one has to be the favourite, it’ll be a bugger to fit and make the connections down there, but that’s where the coolant hoses are and the finished job will be much neater.
All opinions valued ”“ particularly with component location.
