[/URL]
[/URL]
[/URL]
[/URL]Moderator: martauto
[/URL]
[/URL]
[/URL]
[/URL]
zd3bx wrote:If the fan is touching the pipe and has actually ripped it, then you possibly have the fan fitted other way round, cooling the engine, rather than the radiator...
Make sure it faces the radiator, I had this problem on mine, luckily discovered it before the pipe got ripped.
For coolant change, see this > http://www.e30zone.net/e30zonewiki/inde ... ant_Change
P.S. That's assuming you've got an M20.
