Clutch problem
Post Sat Jun 13, 2015 4:51 pm
Hi all, I'm having a clutch issue and don't know where to start to find out what the problem is, a few weeks ago the clutch biting point dropped a bit and the peddle became a little floppy, since then it has been doing it but then goes back to normal, there's no clutch smell whilst driving, today the car almost feels like it didn't want to move, the clutch wasn't dragging, the car was just juddering, and now it feels a lot better, how do I go about checking the cylinders? Thanks
jmc330i
Post Sat Jun 13, 2015 5:49 pm
Have you checked the clutch fluid level?
James
'91 325i Sport
'93 318i touring 16v
Post Sat Jun 13, 2015 5:56 pm
Just checked it, it's bone dry
jmc330i
Post Sat Jun 13, 2015 6:01 pm
Fill it and check for leaks. You will most probably need to bleed it if it's got that low as you'll more than likely have some air in there after you fill it.
James
'91 325i Sport
Post Sat Jun 13, 2015 6:39 pm
Where should I look for the leak? Should I be looking where the cylinders are, where are the cylinders?
Post Sat Jun 13, 2015 6:40 pm
It's a 318, don't know if that makes a difference
jmc330i
Post Sat Jun 13, 2015 6:53 pm
Either a puddle of fluid under the car (slave cylinder) or in the drivers footwell (master cylinder). If either cylinders leak, it's best to replace both at the same time.
You could be lucky and its just low on fluid, so once filled keep an eye on the level and look for small leaks over a day or two. But I'd personally prepare to get both cylinders changed soon if you don't know when they were lasted changed.
http://www.e30zone.net/e30zonewiki/inde ... n_Problems
James
'91 325i Sport
Post Sat Jun 13, 2015 6:59 pm
Thank you jmc for your advice, much appreciated, the car feels totally different since putting the fluid in, thanks again
Post Sat Jun 13, 2015 7:06 pm
Are there any do it your self walk throughs on here, or is it best to take it to a mechanic?
chu346
Post Sat Jun 13, 2015 7:10 pm
blazed
Post Sat Jun 13, 2015 7:12 pm
