Pass me the fookin tongs moosh floor done
Or even a basic multimeter to measure the resistance across the terminals.
spook
- League two here we come !!!
Right in for pre Mot today,ABS light on, the mechanic put a code reader on the car and reported right rear valve?
I have tried new ABS sensors on both sides at the back of the car tonight with no joy,any ideas?
maxfield
Don't suppoae you've got the code have you?
When you say valve, sounds like it could be module related.
spook
The chap did say code 96, well it rings a bell anyway Max.
If it is the module Chris, look up BBA reman over in kent. They did my 530 one. Good price and quick turn around.
spook
Will do Trev,cheers mate.
maxfield
Could really do with finding out more detail about the code and what it said.
spook
Another problem, I have reset my service lights and the car will not start,managed to get it going yesterday by using the key to unlock/lock the turd now back to square one.
spook
Now sorted on the non start problem
spook
Is it fook, car is turning over but it's almost like it's getting no fuel ,or could this be the immobiliser ?spook wrote:Now sorted on the non start problem
spook
How straightforward is EWS delete on these turds?
Its as straightforward as the ECU in a jiffy bag with my address on it
If its an EWS problem the starter wouldnt be turning, does it also have an aftermarket alarm immobiliser?
spook
Dan the car turns over just once each time I go to start it
Ring me if you want Chris
spook
Today I managed to blag a diagnostic scanner and here are the results
Faults and code numbers
10 Inductive crankshaft sensor
01 fuel pump relay,EKP relay
52 Fr wheel speed sensor
54 Rl rear wheel sensor
74 Rl wheel speed sensor not detected
42 EWS signal faulty
40 key no5 faulty identification ?.
Then I did a check on the ECU
Start enabled
DME enabled
Start enabled
DME enabled
spook
It runs,it fooking runs.
Shamone mutha fucka
what was it in the end?
spook
EWS fault mate, cleared using carman scanner borrowed off a mate through E46 M3 mode and not E36. I have fixed all other faults the scanner picked up by replacing the parts.
MOT tomorrow
MOT tomorrow
spook
Had to put the turd into Etech Motorsport in the end due to the non start problem,all problems now sorted and Twelve months MOT.
Jon_Bmw
- Dangerous when thinking
At least they are appreciating nicely Chris, it makes paying out on them easier to stomach!
Did they say what the problem was? I still have my S54, I have a difficult dilemma of when to sell it. I am tempted to sell and put a few more quid in the coffers and try a 996 turbo or early v8 vantage. I'd look a proper bell end in either mind. I'd also be pretty gutted if the z3m ever made it to z8 level pricing and I had sold it now for 25-30k.
spook
It was just a loose connection Jon, Justin found it in the end,something to due with the big C101 plug as they are known on E30s.
I wouldn't sell just yet mate,I would hold on for another couple of years yet, I would not like to pay out for Aston parts fook that mate
spook
I am getting shot of this turd, incoming yank forces sale, pm if interested
Jon_Bmw
It seems the new owner is also getting shot.
Was he the prize chump he appears to be in this thread?
http://www.z3mcoupe.com/forum/showthread.php?t=19405
To be honest he sounds like someone who owns a Polish car wash...oh right, he is!
What did he pay you?
Jon_Bmw
Doh, it's been quarantined!
