H&r anti roll bar
heathy325
Thinking of getting a rear h&r anti roll bar for the e30 just wanted thoughts on this have anyone else got one? If so how much stiffer do they make the rear
Put some proper wheels / tyres on your car. That will make much more difference than thicker roll bars !
kieran325
Mines got H&R front and rear, handles well but that might be due to genuine springs and a full make over with oem bushes etc.
heathy325
Currently running the standard 15"bbs with toyo proxy tyres got h&r cup kit suspension it's fully polly bushed front and rear but my only trouble is when changing direction at speed like accelerating round a roundabout then Turing left the rear feels very wollowey and not planted so just trying to minimise the rear body roll
400motor
Moving the front drop link to the strut massively improves body roll for a fraction of the price while also improving the rear
Cypriotgeeza
More info on this please400motor wrote:Moving the front drop link to the strut massively improves body roll for a fraction of the price while also improving the rear
Check my M30 build threads:
heathy325
Ye info please I've never heard this before
zd3bx
Possibly just your rear ARB links and bushes are knackered? Also going for 16" with lower profile tyres might help.
ala e30 M3's400motor wrote:Moving the front drop link to the strut massively improves body roll for a fraction of the price while also improving the rear
ross_jsy
I looked into it, have seen people using collars like some coil overs use, although welding a tab onto the strut would be just as easy.heathy325 wrote:Ye info please I've never heard this before
Remember, thicker ARB's reduce grip on the axle they are fitted to, use them for tuning handling balance
bosers
I changed my rear subframe bushes, helped a lot with handling. Getting a front strut brace soon, hopefully that'll improve it even more!
heathy325
All the bushes are new in mine and the suspension is only a month old!! I've got a rear brace cuming so I'll keep people posted in what the difference is
pnd
rear bar doesn't do much an uprated front bar will help a lot though.
heathy325
It's the rear that's rolling under hard direction change!!
400motor
Yes as said it's not my idea just copied the m3 setup! I rally an e30 with s50 m3 engine and I have spent 2years developing the handling and suspension, simply moving the anti roll bar links from the lower wishbone standard position to the strut housing directly overhead solved the sloppy body roll front and back, granted I did poly bush all round but after playing round with various suspension setups and spring rates this was the best improvement. Your are basically doubling the rate of the standard one for free.....
