advice on which polybush kit to buy.
matt86
Post Sat May 30, 2015 9:25 pm
Hj,
I'm looking for a full polybush kit and was wondering what other people are running and what would be advised.
Post Sat May 30, 2015 10:13 pm
Best advice I can give is to not use poly :)
gaszman
Post Sat May 30, 2015 10:25 pm
im using poly had no prob just do homework to get the right ones
matt86
Post Sat May 30, 2015 10:39 pm
DanThe wrote:Best advice I can give is to not use poly :)
Thanks Dan, would you just replace them with standard oem new bushes?
Matt
appletree
Post Sat May 30, 2015 11:18 pm
I put some that Dan recommended in the trailing arms on mine and seam good, think they were power flex??
matt86
Post Sat May 30, 2015 11:36 pm
appletree wrote:I put some that Dan recommended in the trailing arms on mine and seam good, think they were power flex??
Ok thanks
Post Sun May 31, 2015 12:35 am
Only time i have used poly is on fatter ARB bushes when they are oversized and can't be bought..
OEM type bushes are perfectly capable and half price so what's the point ?
reggid
Post Sun May 31, 2015 12:56 am
IMO no poly on astreet car except for ARB pushes. lemforder bushes are good
E30 325is with M20B31
Post Sun May 31, 2015 10:11 am
As above! OE are frictionless bearings (ARB excepted). Poly introduces unwanted friction.
Post Sun May 31, 2015 10:32 am
For your road car Matt the only place poly bushes are of benefit are ARB and trailing arms
Superpro - http://www.ebay.co.uk/itm/BMW-E30-3-Ser ... 3a9d05720b
senna
Post Sun May 31, 2015 11:21 am
Don't do it
Ruin the ride
Use OEM/BMW M3 bushes
Demlotcrew
Post Mon Jun 01, 2015 12:30 pm
Next people will be advising to run thicker rear ARB's and ABS :teehee:
