looking to get bbs rm 002
hi im looking to get some bbs rm 002 15x6.5j et33 i believe these are split rims and originals. From what i can remember can you change dishes and get them wider and will it effect the ET if i change the dishes ?
RMs are 2 piece, and as you mention, the lips can be changed for a wider/narrower version. ET is measured from the centerline of the wheel, so changing the lips to a wider/narrower version will change the overall width of the wheel, thus changing the centerline, which in turn changes the ET.
cheers dooce so does that mean that i can go as wide as maybe a 8.5 j rear and 8 j front ?dooce wrote:RMs are 2 piece, and as you mention, the lips can be changed for a wider/narrower version. ET is measured from the centerline of the wheel, so changing the lips to a wider/narrower version will change the overall width of the wheel, thus changing the centerline, which in turn changes the ET.
the et on the wheels im looking at are et33 if that helps .dooce wrote:If I am doing the quick math correctly, you'd need 3" and 3.5" lips to get that width with those wheels and I dont think you'll have the clearance to the wing to run that wide of a lip on an e30
- E30 Zone Meets/Events Team
- Contact:
No, the original lip is 1/2", so you'll need 2" front lips, and 2 1/2 rears, or you'll need to roll and flare the rear arches.dooce wrote:If I am doing the quick math correctly, you'd need 3" and 3.5" lips to get that width with those wheels and I dont think you'll have the clearance to the wing to run that wide of a lip on an e30
sorry for sounding fik so what j will that be then rav on the fronts and back please, and what size tyres u recommend for the fronts n backs pls.Rav335uk wrote:No, the original lip is 1/2", so you'll need 2" front lips, and 2 1/2 rears, or you'll need to roll and flare the rear arches.dooce wrote:If I am doing the quick math correctly, you'd need 3" and 3.5" lips to get that width with those wheels and I dont think you'll have the clearance to the wing to run that wide of a lip on an e30
