205/50 15 Track day / extreme performance tyres
Francisco
Post Mon May 11, 2015 11:02 am
Gents, what's available and what is the feedback on 15' track day/extreme performance rubber for our cars?
Post Mon May 11, 2015 1:21 pm
Depends on the level of grip you have really, for example Toyo 888's are ok for most standardish E30's but anything that can corner and brake well (in track terms) will overheat them quickly
Superleggera
Post Mon May 11, 2015 1:48 pm
DanThe wrote:Depends on the level of grip you have really, for example Toyo 888's are ok for most standardish E30's but anything that can corner and brake well (in track terms) will overheat them quickly
For those slightly more focused track cars what in your experience is better than the r888s ?
Altrezia
Post Mon May 11, 2015 3:39 pm
r888's are fab, but we go through them very quickly in PBMWC. I also like the Yoko A048 which I run on my mini, but I'm sure they'd probably wear at the same rate.
Francisco
Post Mon May 11, 2015 8:59 pm
Altrezia, you guys use R888's for WET conditions as well? Who sells them at best rates?
Is there anything else out there less radical?
Altrezia
Post Mon May 11, 2015 10:50 pm
Yeah we run them in all weather.
Shop around - we get ours from Mike Stokes motorsport down south.
