light Switch's
Grantley
Does anyone know if the bit just above the headlight and fog light switches should have some sort of back light, if they do mine have gone does anyone know what there like to change and or repair ? If its a bitch I'm not worried but would like to have everything working, Thanks
DazzyA
Yeah, there is a bulb behind, I did mine yesterday. You need to take the light dimmer switch panel out. I've got most of the panels off at the moment so was easy, but you will need to remove the under dash panel to get to the 2 large round fixings either side, unscrew the pull switch and push the threaded stud back through. You will then be able to get you're hand up behind. Sounds worse than it is. It's the same bulb as in the ashtrays.
good luck, hope you have little hands
Pass me the spanner
Grantley
Thanks for that mate and thankfully I have well preportioned hands and not fingers like pringels cans !
DazzyA
Nice one, I've got pianist finger's so was ok. You could always play upside down twister to get right in there
Pass me the spanner
Grantley
I think I'll have to mate, looks like a sunday morning with a head like a fooking cherry tomatoe then !
