getting the badge off
xavier
Post Wed Apr 29, 2015 12:00 pm
I just bought a perfect new boot lid. it is off of a late plastic bumper 320i. I want to take the 320i badge off. Any hints on getting it off without wrecking the paint? Heat gun? Plastic spatula?
Cypriotgeeza
Post Wed Apr 29, 2015 12:19 pm
xavier wrote:I just bought a perfect new boot lid. it is off of a late plastic bumper 320i. I want to take the 320i badge off. Any hints on getting it off without wrecking the paint? Heat gun? Plastic spatula?
Plastic trim tool and just be careful..
nothing else to it mate :thumb:
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
cmsslee
Post Wed Apr 29, 2015 12:41 pm
I've always used dental floss to get in behind and 'saw' through the adhesive when debadging. Then AG Tar Remover brings any remaining residue off
Post Wed Apr 29, 2015 1:54 pm
Hot air gun helps, but obviously, don't overdo it.
Post Wed Apr 29, 2015 2:04 pm
i use cotton thread doubled over a good few times so it won't snap, get the thread behind the badge and cut through the glue in a sawing motion then use turps or petrol to get the residue off the bootlid .
if your a convertible owner you can use nail varnish remover instead
:snigger:
baggimodo
Post Wed Apr 29, 2015 2:18 pm
magpie wrote: if your a convertible owner you can use nail varnish remover instead
:snigger:
:P :P :P :P
xavier
Post Sun May 03, 2015 12:20 pm
Thanks. The dental floss snapped so I used fishing line and it went well. I just need to get the glue residue off. The turps sound like a good idea, but turps damage the paint?
Post Sun May 03, 2015 2:32 pm
Bit of heat, and most of the adhesive would have come off with the badge.
Turps won't hurt the paint, and a bit of work will probably be needed with cutting compound in any case, to remove the 'shadow' caused by unfaded paint where the badge was.
