Hi Guys,
I am new to the forum, at the moment my e30
Going for a body restoration, and rhino in to upgrade the
Suspension do you guys have any recommodations??,
Suspension upgrade
Suspension doesn't as much need 'upgrading' as 'restoring'. Your 100,000+ mile dampers are little more than ornaments by now, and your suspension bushes would probably be more at home on a Ford Mondeo.
This has all been discussed on here many times, and the discussion usually veers towards Eibech or H&R -35mm springs, Bilstein B4 dampers all round, E30 M3 eccentric front control arm bushes, E46 cabriolet rear damper top mounts, Mondeo estate rear anti roll bar links for the front roll bar on the E30, and standard OEM rubber bushes for everything else, perhaps coupled with an E46 steering rack.
jmc330i
Brian, do you happen to have an ECP/Carpartsforless part number for the Lemforder E46 cabriolet rear shock mounts? The only Lemforder ones I can find for the E46 look nothing like rear top mounts
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
ZZBADO
Any recommendations on where to get them from??
pimpmobil
Looking at the Mondeo parts, does it matter what year the car is?
- **BANNED**
00/07 I believe.pimpmobil wrote:Looking at the Mondeo parts, does it matter what year the car is?
Youth is wasted on the young.
pimpmobil
Thank you
BenHar
