Urm whats going on ere then..
craigieeb
Post Mon Apr 27, 2015 3:28 pm
Passenger side..
Drivers side......
I was out yesterday for a "spirited drive" and after a couple of hours I heard a slight rubbing coming from the rear.
and today I've noticed the whole rear end has shifted over to the passenger side, quite a fair bit
I've been under and the trailing arm bushes are still good as new and so are the beam bushes, (polly bushes btw)
and cant see anything obvious,
does anyone know of any measurements I can do to see if either the trailing arms or the beam is bent :D
Ianb
Post Mon Apr 27, 2015 4:24 pm
Check the upper shock mounts ......Have they torn out of the inner arches ? Happened to me on an old 323i years ago but I remember the banging was horrendous so unlikely here
87mtech27
Post Mon Apr 27, 2015 4:28 pm
Maybe the inner arches have given way?
craigieeb
Ianb wrote:Check the upper shock mounts ......Have they torn out of the inner arches ? Happened to me on an old 323i years ago but I remember the banging was horrendous so unlikely here
Yeah they do make a right old clatter when they've gone,
But mine are fully intact :)
something's bent somewhere lol I just don't know what yet
craigieeb
Post Mon Apr 27, 2015 4:29 pm
87mtech27 wrote:Maybe the inner arches have given way?
There's nothing torn/rusted away and they don't look out of shape, well to the naked eye anyway
Demlotcrew
Post Mon Apr 27, 2015 4:36 pm
Both sides are level from ground to highest point in the arch lip?
craigieeb
Post Mon Apr 27, 2015 4:45 pm
Hmm just measured..
passenger side is 570
drivers side 565
so a 5mm difference
it also looks like there is more "camber" on the drivers side than the passenger
so......trailing arm mebbies..?
bosers
Post Mon Apr 27, 2015 4:49 pm
50mm from those figures. That'd be a massive difference
bosers
Post Mon Apr 27, 2015 4:50 pm
Subframe bushes?
craigieeb
Post Mon Apr 27, 2015 4:51 pm
My bad, edited
Demlotcrew
I would expect the side which is most recessed at the top to have the most camber (if everything else is ok).
I have seen cars with broken front suspension components complain of rear geometry issues but in fact its the front which is the problem.
I personally think that Poly bushes are nothing but rubbish, but thats for another topic.......
craigieeb
Post Mon Apr 27, 2015 4:53 pm
bosers wrote:Subframe bushes?
They look good to me, just as fresh as when I put them in
bosers
Post Mon Apr 27, 2015 4:57 pm
Might want to edit it again? Hope it works out for you bud.
oomz1975
Post Tue Apr 28, 2015 9:32 pm
I have exactly the same issue at the moment.....
Rear beam bushes still look fresh on mine too.
I'm suspecting the rear upper mounts, as there is a knocking sound & that is one area that I haven't been yet.
Going to have a proper suspension overhaul very soon, so hopefully sorts out any annoying rubbing issues.
bosers
Post Tue Apr 28, 2015 10:07 pm
Sorry mate, didn't want to be a smart arse. See you've got the numbers right now... Hope it works out ok.
craigieeb
Post Tue Apr 28, 2015 10:26 pm
oomz1975 wrote:I have exactly the same issue at the moment.....
I pulled the shocks off yesterday and my top mounts are perfect, checked to see if the shocks were knackered and their not.
Pulled the springs out to check them and their identical,
Gave the trailing arms a good old prod/wiggle with a pry bar where they mount to the beam and there was no untoward movement,
Pulled the bottom plates off the main beam bushes to check them and they are still factory fresh.
And when I put the shocks and springs back on, I swapped them over, driver to passenger side & vice versa,
Guess what,
Still the same
BenHar
Post Tue Apr 28, 2015 10:41 pm
How do you know anything has changed?
Do you have measurements from earlier to compare it with?
Are there any signs of any rubbing?
Ben
craigieeb
Post Tue Apr 28, 2015 10:48 pm
BenHar wrote:How do you know anything has changed?
Ben
Not sure i know what you mean????
Both rear wheels were straight now one has excessive camber and the other is rubbing on the outer arch.
Yes there is signs of the passenger side rear rubbing
There's obviously been a change or I wouldn't of posted this thread
BenHar
Post Tue Apr 28, 2015 10:51 pm
I just wondered if you had held a tape measure to it before.
It is difficult to tell anything from the pictures.
Might help if you took some more fro different angles.
Ben
craigieeb
Post Tue Apr 28, 2015 10:58 pm
Never needed to fella,
I know the car back to front and inside out
It's never rubbed on the rear, ever,
it didn't at the start of the day, but did at the end of a full day of a rather good seeing to.
BenHar
Post Tue Apr 28, 2015 11:08 pm
For the camber to change either the spring height has changed or the trailing arm is bent.
Ben
Post Wed Apr 29, 2015 9:24 am
Has it started rubbing since you fitted your new wheel spacers? :)
craigieeb
Post Wed Apr 29, 2015 2:04 pm
Well, yes and no lol
Yes the 5mm spacers are fitted and the car has been used a couple of times since fitting them,
But when they were fitted, both wheels were nice and straight and there were no rubbing issues
The rubbing on one side only started after a day of boosting allover the world on the Sunday.
I'm taking the car to see a "car straightening guy" who should be able to tell me what's what.
But before I do, I would like to see if I can find the fault my self,
which is why I wanted some factory measurements
